temp guage going bananas!
Old Aug 4, 2009 | 03:57 PM
sumoneEK's Avatar
Default temp guage going bananas!
1st i wanna welcome my self back.. I sold my ek b16 swap for a is300 never again
So now I'm back ek baby!! It felt like I sold my soul to the devil
I'm back with more questions
This is my problem yesterday as I was driving around my ac was blowing hot air, I went to a junk yard when I return my car
The car didn't want to start and engine light came on.. So finally it urned on and I started driving to autozone the car turned off on me .. I lift the Hood and my coolent was empty
I let the car cool down and turned it on and went to autozon checked the cel and it gave me p0117
I put in coolent and started the car and it worked fine I cleared the cel and it did not appear again
My temp gauge does not work so I didn't know it was over heating
I bought a si cluster today to connect and see the temp .. But now when I drive the temp needle goes crazy.. When I give gas it goes down
When I turn the car to ignition it shows the temp
What's going here???
And who I bought the ek from he bypass the wire do the fan can be on all the time
Any one any input?
Old Aug 4, 2009 | 05:04 PM
black0hatch's Avatar
Default Re: temp guage going bananas!
the fan being on all the time has nothing to do with the temp guage sensor. i had a similar problem when i mashed the gas the temp guage died then let off and it worked. turned out the plug wasnt pluged in all the way. i would say check the plug and wire.
Old Aug 4, 2009 | 05:06 PM
sumoneEK's Avatar
Word! Were can I find this plug?
Old Aug 4, 2009 | 06:08 PM
East's Avatar
my tach is like that (si cluster) the plug/wire on the dizzy is loose.... (not sure if thats the same area)
try make sure the connections/plugs on the back of the cluster is in securely.
Old Aug 4, 2009 | 06:19 PM
sumoneEK's Avatar
What plug are u talkin about?
Old Aug 4, 2009 | 06:21 PM
sumoneEK's Avatar
Is ur tach still like that?
Old Aug 4, 2009 | 07:37 PM
Former User's Avatar
Any one any input?
I think you need to top off the radiator and reservoir with coolant, push the heater lever to max heat, install the radiator cap loosely, and let the engine idle until the cooling fan turns on twice (may take 20 minutes or so). This should bleed the air out of the cooling system and stabilize the dash temp gauge.
Old Aug 4, 2009 | 07:51 PM
kal727's Avatar
same thing happend to me it was a ground wire from the motor to the chassis
Old Aug 5, 2009 | 08:44 AM
sumoneEK's Avatar
the pervious owner bypass the fan so it can be on at all times...
now i dont know if he did this for a reason ... but how would i know if i clip back the fan switch the fan works?
Old Aug 5, 2009 | 08:52 AM
sumoneEK's Avatar
im about to just do a coolant flush but this DIY aint showing the pics...
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-flush-coolant-system-change-thermostat-56k%3Dno-way-1424191/
Old Aug 5, 2009 | 08:57 AM
https://honda-tech.com/forums/showthread.php?t=1424191
Just let the engine idle for about 20 minutes. Putting the front end on stands may help get all the air out of the cooling system.
Old Aug 5, 2009 | 08:59 AM
sumoneEK's Avatar
awsome im about to jump on that right now for my break! ill let you know. GRACIAS!
Old Aug 5, 2009 | 09:00 AM
No need to do a flush (drain, flush, refill, bleed). Just bleed the system.
Old Aug 5, 2009 | 10:48 AM
sumoneEK's Avatar
well imma have to try this when i get home boss caught me playin with my car...
Check terminal B10 of connector B at the back of the gauge assembly (see diagrams above and below). It may be bent or damaged, causing it to ground out.
as i put the car up the car ran out of gas ... stupid me ... but the gas gauge was on above E like if i had gas... but i really didnt
i bought this si cluster and now my gas gauge aint working on this si cluster and i checked out b10 ... would you know how to remove the gauge and ill but my ex one on??
Old Aug 5, 2009 | 11:41 AM
Diagrams posted at this thread show how to test the gas gauge and sending unit.
Old Aug 5, 2009 | 11:49 AM
sumoneEK's Avatar
It works fine with my EX cluster now im putting the SI cluster and the needle wont move ... Do u think if i take out the gauge from the EX and put it on the SI would work? cuase to tell u the truth i think its the gauge thats not working when i put the needle all the way up it wont go all the way down .. and when i do put it all the way down it goes up passed the E ... and it happens when it even unplugged
Old Aug 5, 2009 | 11:51 AM
Might still be worth testing, though I do understand your point.
Old Aug 5, 2009 | 11:56 AM
sumoneEK's Avatar
how do i take this apart??
Old Aug 5, 2009 | 11:57 AM
sumoneEK's Avatar
Will do as soon as i clock out! lol
Azavala
May 1, 2014 05:24 PM
bakomack
12
Jan 24, 2011 03:24 PM
folta2169
Dec 3, 2007 03:14 PM
DEL_SOL_BELLA
Dec 7, 2005 08:36 PM
self_made
Jan 4, 2004 08:06 PM
