JDM EF8 SiR exhaust
Old Aug 3, 2009 | 09:44 AM
dmlemus's Avatar
Default JDM EF8 SiR exhaust
Does anyone know what this sounds like?
Old Aug 3, 2009 | 10:31 AM
speckles's Avatar
Default Re: JDM EF8 SiR exhaust
with or without a cat? DCRB has my old hatch and without a cat (I had a EF9 SiR OEM cat back on it) it sounds good, not loud, but not super quiet. Worth the money if you find one.
Old Aug 3, 2009 | 10:35 AM
dmlemus's Avatar
Running with cat. I bought the SiR axle back muffler only, 100 bucks.
It is not a direct bolt-on so I have to cut and weld for it to fit properly. Anyone know of a good muffler shop in Los Angeles?
Old Aug 3, 2009 | 03:55 PM
speckles's Avatar
Son, it IS a direct bolt on. All you gotta do is work with it and man it in there. I had the axle back on my STD b piping, fit just fine.
100 bucks for JUST the axle back? thats a rip off! i got the whole cat back for 80$ delivered to my door
Old Aug 3, 2009 | 05:42 PM
dmlemus's Avatar
The axle back came of from a rhd sir in japan. removing the stock si axle back shows the opening to be a little bigger than the sir one, it won't easily bolt on directly to the pipe.
that's why I gotta cut.
Old Aug 3, 2009 | 05:53 PM
Mr. DeOro's Avatar
Thats because you have to weld it in. the cat back bolts up to the cat.
Old Aug 3, 2009 | 05:58 PM
dmlemus's Avatar
I am running the d16 piping. any difference from the std b piping? maybe that's where my problems are coming from. I am using all std d16 piping to bolt on the sir axle back.
Old Nov 4, 2009 | 02:30 PM
tnez's Avatar
if anything... I would have thought that the SiR was a tad larger. Weird.
Old Nov 4, 2009 | 03:29 PM
dmlemus's Avatar
well the piping seemed smaller but the canister is a lot bigger!
Old Nov 4, 2009 | 03:37 PM
garageEF's Avatar
Mine bolted to stock B-pipe with NO problems.
Sounds like stock exhaust, because it IS stock exhaust.
Old Nov 4, 2009 | 03:47 PM
DCRB's Avatar
sure your's is from honda? mine is. it is much louder than a stock exhaust. granted it's 2.25" piping (i think) but it's better than the stock exhaust that came on our 1.5l's. i recently swapped out my b pipe (which had crush bent angles) with my obx-r b pipe and it's like 2.5" piping that's mandrel bent all the way back until the axle flange, where it shrinks down and bolts right up to my muffler. looks stock.
Alexpbnj
Nov 20, 2010 04:15 PM
TrickHonda98
Sep 5, 2003 07:09 PM
deeweezy
Dec 5, 2002 12:28 PM
playabill19
27
Apr 11, 2002 09:36 AM
RACERSIR
Jan 11, 2002 09:08 AM
