throttle body question
Old Aug 1, 2009 | 09:16 AM
that_boy_sammy's Avatar
Default throttle body question
i got a 99 civic d16y8 5spd
i took the throttle body off to clean it and clean the iacv....when i went to tighten the nut back to the throttle cable line the bolt broke because i tightened it too much...so i went to the junk yard and ripped a throttle body out of a d15 which was automatic...now my car is over reving at 2000rpms when driving and puttin it in neutral.When i come to a complete stop it fluctuates from 1000rpms to 2000rpms or sometimes itll just stay at 2000 rpms.If i loosen the throttle cable the rpms go down, but then my car starts to boggle..and when i tighten it back up it does what its doing now.
I am guessing its doing this because i took it off an automatic? or any other thoughts? should i order the correct one from a honda dealership?
Old Aug 1, 2009 | 09:34 AM
Former User's Avatar
Default Re: throttle body question
Not sure if the IACV from the D15 will work with your Y8. In addition, the D15 likely has an FITV. Try cleaning it out. The throttle cable must have some slack (~1/2").
Old Aug 1, 2009 | 09:46 AM
also, there isnt a sensor on top of the throttle body like my old one so the check engine light is on
Old Aug 1, 2009 | 09:50 AM
What!!! You must have a MAP sensor. Get a different throttle body more compatible with the Y8.
Old Aug 1, 2009 | 09:54 AM
j0keefe21's Avatar
yea you kinda need a map sensor
Old Aug 1, 2009 | 02:06 PM
lol fa sho ...i had to special order it from honda...384 dollars my nigs
nokturne
Mar 25, 2010 05:03 PM
monkalotamus
Nov 15, 2006 06:31 PM
LSVTEC 91 Civic
15
Oct 28, 2005 06:16 PM
jleib
22
Mar 28, 2005 05:22 AM
rasta420
Mar 18, 2003 10:42 AM
