idle system malfunction
Old Jul 31, 2009 | 08:46 PM
altoid04's Avatar
Default idle system malfunction
my check engine light came on and i checked it at an auto parts store and it said that it had an idle system malfunction. how can i fix that without spending 300 bucks on a new unit?
Old Jul 31, 2009 | 09:17 PM
Davus's Avatar
Default Re: idle system malfunction
Spend 2% of that on a can of carb cleaner and start spraying around the vacuum lines, intake manifold, fuel injectors, etc. and see if you can find a place that makes the car idle funnier, or nearly stall. Likely a vacuum leak.
You could also clean your idle air control valve if it turns out that is the culprit.
Old Jul 31, 2009 | 09:19 PM
Former User's Avatar
There is more than one IACV code for OBDII Civics. Each code requires different troubleshooting. Was your code P0505 or P1508/P1509?
Old Aug 1, 2009 | 10:36 AM
altoid04's Avatar
the code is P0505
Old Aug 1, 2009 | 10:44 AM
Is the idle speed too high, too low, or fluctuating between high and low?
Old Aug 1, 2009 | 10:56 AM
altoid04's Avatar
it goes high and low. when it idles the A/C and the lights on the dash come in and out. like they fade and come back
Old Aug 1, 2009 | 11:00 AM
With the warm engine idling and the intake/air cleaner removed, use your finger to cover the port in the throttle body leading to the IACV . Does the fluctuation in idle speed stop?
Old Aug 1, 2009 | 11:06 AM
altoid04's Avatar
i'll have to check that when i get home from work
Old Aug 1, 2009 | 01:44 PM
altoid04's Avatar
i forgot to mention that i just got a new A/C compressor put in and it only idles funny when the A/C is on
Old Aug 1, 2009 | 02:03 PM
Was the compressor clutch relay wired through the ECU so that the engine will idle up when the A/C is turned ON?
Old Aug 1, 2009 | 08:09 PM
altoid04's Avatar
i have no idea, how do i find out? i'm not to car savvy
Old Dec 12, 2009 | 07:20 PM
ramzy452's Avatar
New User
what are the fixes for the p0505 idle control system malfunction.
Old Dec 12, 2009 | 07:22 PM
ramzy452's Avatar
New User
are the parts expensive for the idle control system.
John F
12
Nov 28, 2007 08:00 AM
premo_si
Aug 29, 2006 07:33 PM
c0nspire
Feb 23, 2006 02:09 PM
Glocked1
12
Jan 22, 2004 08:13 PM
