gauges going crazy!
Old Jul 29, 2009 | 07:23 PM
silverwrench's Avatar
Default gauges going crazy!
hi, i have a 95 civic sedan auto dx, i just put in a gauge cluster from a 94 civic sedan manual ex. everything works except when i turn the high beams on the tachometer goes to 0 and when i turn the blinkers on the tachometer goes up and down in rhythm with the blinker. also the fuel gauge seems to be reading twice as much fuel than i actually have. so what is cause the tach to go crazy? if its because the cluster is for a manual and i have a auto can i fix this? and any idea on why the fuel gauge isn't reading right?
thanks in advance for any help
Old Jul 29, 2009 | 08:06 PM
SlickEJ8's Avatar
Default Re: gauges going crazy!
i had the same problem with my integra it was the battery ground wire. check that and all you connections. hope that helps
Old Jul 29, 2009 | 08:31 PM
ok i'll check that tomorrow, thanks
Old Aug 6, 2009 | 06:44 PM
bump
Old Aug 7, 2009 | 05:26 AM
fcm's Avatar
fcm
Old Fart
When one circuit, [high beams] has an effect on another "unrelated circuit", [tach] it is almost always due to a grounding issue.
I would check wiring at the cluster and the cluster itself. 94
Old Aug 9, 2009 | 08:17 PM
well i couldn't find a problem so i'm going to get another one
slammedem1
Mar 8, 2010 02:47 AM
ReDemoN
Jan 9, 2009 04:01 PM
4drSi
May 26, 2007 01:05 PM
importracegirl
Nov 29, 2006 11:18 AM
hondasleeper
10
Sep 20, 2004 08:45 AM
