Civic failed emissions horribly
I took my civic to get emissions done and here are the results
25/25 Test Reading----------Allowed
HC ppm----402--------------147 Fail
CO %------2.03-------------0.82 Fail
NOx ppm---1413------------1072 Fail
RPM--------2024------------3000 Max
CO+CO2----15.08-----------6.00 Min
50/15 Test Reading---------Allowed
HC ppm----364--------------152 Fail
CO %------1.40-------------0.85 Fail
NOx ppm---1453------------1186 Fail
RPM--------1860-----------3000 Max
CO+CO2----14.92-----------6.00 Min
what all should I change/use to get it to pass? sorry if this is the wrong forum
Georgia
95 civic Ex
d16z6
CEL is NOT on..
Georgia
95 civic Ex
d16z6
CEL is NOT on..
like ronj said start with a tuneup then. it appears either your engine isnt burning the fuel properly, or your catalytic converter isnt burning enough leftover fuel. hence your HC and nox is high....
I wish.. lol
Not technical but its an option. but for Technical help. Id remove any after market fuel pump. Replace your cat. and be sure both O2 sensors are working properly. But if there is no CEL then there may not be an O2 sensor problem. If you have a Walbro 255 then that cranks more volume of fuel in there at the same pressure. the pressure regulator only controls the pressure but the volume will still change depending on the liters per hour your fuel pump can handle. Check your sparkplugs and be sure that they are clean and the spacing is correct. If they arent burning as much fuel as they are supposed to that could be a problem. possibly get larger diameter sparkplug wires.
Perhaps an oil change may help also. fresh oil so the motor doesent have to work as hard to turn with old oil
riiiiiiight.... start witha tune up lol
eghatch9295
14
Jun 8, 2016 04:10 PM
95jeremie
10
Jul 8, 2009 07:25 AM
Vertex Spirit
Aug 29, 2008 09:19 PM
