Help me!! fuel problem! d16 turbo.. wont start!
Old Jul 28, 2009 | 10:19 AM
josejdm's Avatar
Default Help me!! fuel problem! d16 turbo.. wont start!
car wont start.. just turns and dont start. can't hear the fuel pump.. but ran it direct and it turns on... help!
Old Jul 28, 2009 | 10:21 AM
bukkowben's Avatar
Default Re: Help me!! fuel problem! d16 turbo.. wont start!
did you check the main relay? usually that the culprit if your pump isnt even turning on. Its under your dash above the clutch pedal.
Old Jul 28, 2009 | 10:24 AM
josejdm's Avatar
yea..i bought a new one.. and still nothing.. so i returned it..
Old Jul 28, 2009 | 10:31 AM
MadScientistMatt's Avatar
Did this no start condition suddenly happen to an otherwise running car, or did you do any mods before this happened?
josejdm's Avatar
a friend told me it might be my ecu.. but its not that. i just tried my buddies p 28 and still nothing... help!
Old Jul 28, 2009 | 10:33 AM
josejdm's Avatar
it just didn't turn on one day..
Old Jul 28, 2009 | 10:38 AM
I'd first check the fuel pump fuse and relay then.
Old Jul 28, 2009 | 10:43 AM
josejdm's Avatar
would that fuse be under the hood or inside the car?
Old Jul 28, 2009 | 12:31 PM
Former User's Avatar
92-95 Civics -- check fuses 31 (hood), 24 (dash), and 18 (dash).
96-00 Civics -- check fuses 44 (hood), 31 (dash), and 13 (dash).
Is the CEL ON? If so, are you able to pull a code? Do you also lack spark? Have you checked the important ground wire on the thermostat housing?
Jose A Aispuro
Jan 6, 2017 05:18 PM
byc_cb7
47
Feb 6, 2010 12:01 PM
92redhatch
38
Aug 3, 2006 04:51 PM
jbscivichb92
Apr 25, 2005 08:31 PM
zdr262
Jan 30, 2002 09:34 AM
