1992 civic cx with b16a2 fuel pump wont turn on. HELP!!!!!!!!!
Old 07-31-2006, 10:44 AM
92redhatch's Avatar
Default 1992 civic cx with b16a2 fuel pump wont turn on. HELP!!!!!!!!!
So i just finished building my b16. After i finished installing it in the car. I go to turn on the car and the fuel pump wont turn on! The motor turns over but the fuel pump doesnt turn on. So i check all the fuses and i see that the fuse for the ecu in the engine bay is bad so i replace it. I then try again an still nothing. What can my problem be???
Old 07-31-2006, 10:45 AM
92redhatch's Avatar
Someone told me it could be the main relay. Im going to check that out asap.
Old 07-31-2006, 10:52 AM
CO_HaTcH's Avatar
Default Re: (92redhatch)
dude... seriously i had the same problem.. what i did.. i got pissed after a perfect install, my fuel pump didnt engage.... so i got pissed read up online, someone said just kind of hit ur dash a little.. well i hit my dash, and bam it came right on.. lol try that man.. but ya its the main relay..
Old 07-31-2006, 10:53 AM
92redhatch's Avatar
Default Re: (CO_HaTcH)
do you know where the main relay is? and what it looks like? Someone also told me to hit the relay so it will get unstuck.
Old 07-31-2006, 10:58 AM
cute little bastard
SkoundrelUSA's Avatar
I don't understand how it could be the relay after doing a swap. But I guess you can check
its located near the fuse box inside the car (under the driverside dash area)
looks like this (the grey box)
Is your ignition switch working properly?
Old 07-31-2006, 10:59 AM
92redhatch's Avatar
my ignition works perfect im going to check it out right now
Old 07-31-2006, 11:13 AM
92redhatch's Avatar
relay is fine
Old 07-31-2006, 11:14 AM
92redhatch's Avatar
what else can it be
Old 07-31-2006, 11:21 AM
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch &raquo;</TD></TR><TR><TD CLASS="quote">relay is fine</TD></TR></TABLE>
How do you know its fine? Did you try it in another car or something?
Old 07-31-2006, 11:24 AM
cute little bastard
Default Re: (SkoundrelUSA)
maybe...
https://honda-tech.com/zerothread?id=1320931
92redhatch's Avatar
tried it on my friends ek. There is no spark. I thought there was but there isnt any. What could it be?
Old 07-31-2006, 11:49 AM
92redhatch's Avatar
we just finished trying my main relay on my friends EK for the second time and now it doesnt work. One of my nitrous line maid a short circuit on one of the relay lines. So im going to replace the relay and see if thats my problem.
Old 07-31-2006, 11:58 AM
CO_HaTcH's Avatar
Dude honestly.. im not trying to be a jackass but i basically beated on my side of the dash.. flip the key forward, then back.. hit it again... waiting for the pump to engage so im telling beat it a little.. try it.. lol on hot days hondas are known for it man.. good luck
Old 07-31-2006, 12:01 PM
FalkenSiR's Avatar
Your relay is bad then.
Old 07-31-2006, 12:03 PM
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CO_HaTcH &raquo;</TD></TR><TR><TD CLASS="quote">Dude honestly.. im not trying to be a jackass but i basically beated on my side of the dash.. flip the key forward, then back.. hit it again... waiting for the pump to engage so im telling beat it a little.. try it.. lol on hot days hondas are known for it man.. good luck</TD></TR></TABLE>
lol it may have worked for you but that isn't exactly a "proper fixture". You probably have a relay thats also going bad if its happening on hot days.
Old 07-31-2006, 12:06 PM
CO_HaTcH's Avatar
ya it was.. but i mean to get the car just to run and get to the store it worked for me lol.. but ya it was my relay it didnt look bad.. but on hot days something about it was just old and would no longer touch the connectors.. so ya i just replaced in the long run.. but i sure as hell gave it a good beating before i replaced for all the hassle it gave me lol
Old 07-31-2006, 12:14 PM
92redhatch's Avatar
i gave it beating. Trust me. When i try to turn the car on i feel the main relay click but still no fuel pump. So im waiting for m friend to get back so i can try his relay.
Old 07-31-2006, 12:32 PM
CO_HaTcH's Avatar
alright sounds good let us know how it works.. did u beat the relay or the side of your dash?? because i hit on the side of my dash where the relay was at.. and for some reason that seemed to work.. so let us know how it turns out
Old 07-31-2006, 06:03 PM
92redhatch's Avatar
i changed the main relay and the fuel pump still doesnt turn on. And yet again the fuse for the ecu in the engine bay is broken.
Old 07-31-2006, 06:08 PM
Syndacate's Avatar
there's a short someplace with ur ECU and main relay, I'd suggest taking it to a shop that specializes in electronics
If you just popped 2 ECU fuses like that and ur not getting the pump to prime, the circuit between the ECU and the main relay must be bad, I'm tellin ya, take it to a professional auto electrician, they can find the problem is &lt;1hr and get it fixed :-\
Old 07-31-2006, 08:46 PM
92redhatch's Avatar
im going to check it out tommorrow and if still nothing then ill call a buddy of mine thats honda certified and really good with wiring.
Old 07-31-2006, 09:23 PM
cute little bastard
you don't happen to have a VAFC do you?
Old 08-01-2006, 08:09 AM
92redhatch's Avatar
no vafc
Old 08-01-2006, 08:16 AM
WhiteOnRice's Avatar
This may sound stupid, but you may have gotten vapor lock while the engine was out. Hit the gas tank/fuel pump with a rubber mallet while turning the key. It may not work since the fuel pump isn't even turning on but may as well try. Worked on my friend's b16 swap...
Old 08-01-2006, 08:21 AM
cute little bastard
If you keep blowing the ECU fuse, something is definitly wrong in the wiring. Happened to me, but in my case it was because of my VAFC. One of the ground wires wasn't spliced in correctly and kept blowing the fuses each time I would try to crank it.
Quick Reply: 1992 civic cx with b16a2 fuel pump wont turn on. HELP!!!!!!!!!
