Vtec harness plug
I recently swapped my blown d16y8 for a d16y7, still running the vtec ecu with the vtec wiring harness. I had a crack in my exaust manifold which caused an exaust leak, but i purchased a new manifold today. My question is:
My car has check engine light...is that because of the exaust leak or the Vtec wire not being plugged in(no vtec solenoid on the non-vtec)
Any help would be appreciated because my tags are expired and i just paid my registration, i need to smog asap.
Thanks in advance.
J
Thanks in advance.
J
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Check your CEL. Post results. But most likely, you'll need the proper non-VTEC ecu to get rid of the CEL.
Einhander276
Aug 2, 2011 05:47 PM
LSracing94
17
Aug 7, 2006 10:00 AM
