How do you "Jump" a starter??
93 EX wont turnover checked grounds and battery everything is good. How do you jump the starter? Do you just get wire and touch the two terminals on the starter together? I did that and still nothing?? bad starter??
If you use the screwdriver trick you have to make sure both connections no **** make good contact. Or get a wire and connect one end to the pos side of the battery and the other side connect to the ign wire on the starter. If nothing your starter is done and if it works your ign is not sending the signal to crank
hondachris1994
12
Nov 9, 2017 05:15 PM
tur3oDC4
Sep 17, 2005 09:41 AM
