Notchy feeling gas pedal.. 99 Si
Old Jul 21, 2009 | 10:04 PM
Diversion's Avatar
Default Notchy feeling gas pedal.. 99 Si
Hi I recently picked up a 99 Si that's mostly stock still (luckily) and i'm trying to restore as much as I can little by little.. I noticed the gas pedal has a notchy, sticking feeling.. It dosn't depress smoothly if that makes any sense..
Is there something I can do to make it smooth again or is this something where I need to buy a new throttle cable?
Old Jul 22, 2009 | 12:48 AM
Ruben19's Avatar
Default Re: Notchy feeling gas pedal.. 99 Si
lubricate the pedal with wd-40 and make sure your throttle plate inside the throttle body isn't sticking.
Old Jul 22, 2009 | 05:54 AM
92ehatch's Avatar
lube the throttle spring with some white lithium
pull back the rubber cover on the throttle cable and lube it as well
then take off your intake arm and clean the throttle plate and throttle body with throttle body/carb cleaner.
that should fix it
Old Jul 22, 2009 | 10:38 AM
Diversion's Avatar
Thanks for the tips, will get to work tomorrow on this and report back with results!
Old Jul 22, 2009 | 11:49 AM
Ruben19's Avatar
no problem
Old Jul 22, 2009 | 11:55 AM
Former User's Avatar
You've been given some good suggestions. I'll be interested to know if you find the fix. I've also read that, in some cases, the throttle cable must be replaced to eliminate a notchy feeling throttle pedal. I think you can buy the cable at Majestic for $35-$40, although you only want to try this if the other suggestions don't work.
Old Jul 26, 2009 | 07:23 AM
Diversion's Avatar
Welps, the lithium grease and WD40 semeed like it helped for a day.. but it was also a hot day so things could have been a little looser and I thought we got it feeling a bit better but during a cooler morning otw to work, pedal still notchy and it makes the car buck due to going from a light pedal to half throttle.
Sounds like i'm going to have do what RonJ suggested and order in a new throttle-cable to fix the issue.
I've heard of people recommending a Type R throttle cable? Is there a reason? Better made?
Old Jul 26, 2009 | 07:29 AM
Relic1's Avatar
no difference in throttle cables, only bragging rights. You could claim you used an ITR cable and use one for your car and no one would know the difference.
Unfortunately throttle cables are easy to bend accidentally, once kinked they never come back.
Old Jul 26, 2009 | 07:41 AM
Diversion's Avatar
Bragging rights? lol.. That's what I thought, a throttle cable is a throttle cable. Silly ricers.
Old Jul 26, 2009 | 08:27 AM
Did you also try cleaning the throttle body? Sometimes gunk that can build up in there will prevent the throttle plate from moving freely.
Old Jul 26, 2009 | 08:30 AM
Diversion's Avatar
Called me out! No, I actually didn't do that.. I did buy some carb cleaner.. I was just too lazy to remove the intake and clean it out. I did open and close the throttle plate and it felt pretty normal and smooth.
Old Jul 26, 2009 | 08:42 AM
A thorough cleaning of the TB may be worth trying before purchasing a new throttle cable.
Old Jul 26, 2009 | 09:13 AM
Diversion's Avatar
Point taken, will be cleaning the tbody tomorrow morning and will report back..
Old Jul 28, 2009 | 09:14 PM
Diversion's Avatar
Cleaned the TB really well (emptied a brand new can of carb cleaner on it) and I believe it might have helped a tad.. but the overall stiff/stuck feeling of the pedal comes and goes.. definately sticks more when it's cooler outside.. I guess i'm left with replacing the throttle cable completely now.
I assume a new throttle cable comes pre-greased?
Old Aug 23, 2009 | 07:43 AM
Diversion's Avatar
So I finally got around to ordering a brand new throttle cable from Majestic, it came in last week and on Thursday I installed it onto my Si.
The new cable looked completely different (assuming maybe improved), had a longer rubber end and different metal shaped pieces.
It FIXED my notchy pedal issue 100%.. The car drives so much better now.. it feels like a new car almost! I'm expecting to see better MPG due to smoother throttling going through the gears instead of over-revving out of 1st gear (pedal always stuck badly when trying to ease out in 1st gear).
So, for $17 - highly recommended if you have any doubts in your old, crusty throttle cable - the new one comes pre-greased and ready to be installed the moment it arrives to your door.
Regards,
Div
Old Oct 14, 2009 | 10:25 AM
slk08's Avatar
Regards,
Div
I went to hondaautomotiveparts like you said but i cannot find the part for the price you said. Can someone point out to me what it is suppose to be under and the number of the part on the diagram?
mardoiii
Oct 20, 2008 08:09 PM
85crx509
Sep 3, 2008 11:10 AM
VtecBrian
Feb 20, 2006 06:01 AM
nc_mx_kid
Dec 28, 2004 06:08 PM
udm_motorsport
Mar 24, 2003 09:20 AM
