Will Del sol Rear disc fit on 94 Ex civic coupe???
I just picked up a 94 del sol with rear disc on it. Its beat up so I dont know if its SI?? I want to say it is but it swapped with a single cam.. And has rear disc.. So my question is will the rear disc work on my 1994 honda civic EX coupe.. Any input is appreciated..
thanks
thanks
im not 100%sure on the trailing arms and such from the rear.
but i do know that you WILL need to use the prop valve from the del slow, and i know it will work due to its on my 94 ej1.
the master cylinder should be the same as your coupe.
but the biggest master cylinder that will swap over with no problems is from a 91 civic ex.
its a 15/16ths.
its a 15/16ths.
94EGcoupeh22a
Dec 30, 2006 11:25 PM
whitesiforemala
Sep 20, 2004 08:12 AM
d15nonvtec
Jan 22, 2004 08:21 PM
Slow Egg
Oct 6, 2002 09:29 AM
Propulsion
Mar 24, 2002 04:09 PM
