Will Del sol Rear disc fit on 94 Ex civic coupe???
I just picked up a 94 del sol with rear disc on it. Its beat up so I dont know if its SI?? I want to say it is but it swapped with a single cam.. And has rear disc.. So my question is will the rear disc work on my 1994 honda civic EX coupe.. Any input is appreciated..
thanks
thanks
Re: Will Del sol Rear disc fit on 94 Ex civic coupe???
im not 100%sure on the trailing arms and such from the rear.
but i do know that you WILL need to use the prop valve from the del slow, and i know it will work due to its on my 94 ej1.
the master cylinder should be the same as your coupe.
but the biggest master cylinder that will swap over with no problems is from a 91 civic ex.
its a 15/16ths.
its a 15/16ths.
bump so this looks like it should work... anybody else.. but civics are pretty universal back then so i hope..
94EGcoupeh22a
12-30-2006 11:25 PM
whitesiforemala
09-20-2004 08:12 AM
d15nonvtec
01-22-2004 08:21 PM
Slow Egg
10-06-2002 09:29 AM
Propulsion
03-24-2002 04:09 PM
