Can you Swap Delsol Rear Disk onto a Eg Civic
Re: Can you Swap Delsol Rear Disk onto a Eg Civic (CrotchRocket)
I put 94 Del Sol VTEC front and rear disks on my 93 CX and it worked fine. I just had the get e-brake cables from a 93-95 EX
Re: Can you Swap Delsol Rear Disk onto a Eg Civic (ill phil)
del sol si is the same as hte ex and 5th gen si....the del sol vtec is hte same as the teg gsr....for the front at least
Re: Can you Swap Delsol Rear Disk onto a Eg Civic (JDM93)
direct swap(plug and play)
make sure that the brake lines are not cut...
use the 30/30 proportioning valve.
once, the swap is complete make sure the rear does not lock up before the front brakes...have fun
gmcuajo1
06-22-2014 07:23 AM
