... voltmeter as an a/f ratio gauge - need voltage ranges
... i am planning on using an extra voltmeter that i have here as an a/f ratio gauge... but i need the voltage ranges for lean/stoich/rich... if anyone can help me out i would really appreciate it... thanks... ((also, sources and multiple response are appreciated, thanks))...
A standard one-wrie O2 will provide 0.1V (rich) to 0.9V (lean) with stoic right at 0.45v. It is a sharp transition from rich to lean.
A heated wideband O2 will provide an almost linear response from ~2.7V (rich) to ~4.6 volts (lean). That is one reason why they are so accurate, they have a wider linear band to work with along with other things.
Your volt meter will have to be pretty accurate to correctly display the A/F. it won't be perfect because the voltage is also exhaust temp dependant (how hot the sensor is).
Randy
Randy
What about reading the o2 voltage off the blue wire on my SAFC?
This is from thedropshop
A.2 (Liam182):
.89+ is rich. You wanna tune to around .90 -> .92 on a turbo Honda. I was running around .89 -> .91. Like .95 is too rich.
Hehe, trying to tune the rich end of the scale with a narrow band O2 sensor + voltmeter/af gauge is a bad idea. While you are out shopping for a volt meter you should buy some pistons.
I have a wideband, and often when my Autometer AF gauge connected to stock O2 reads full rich, my wideband reads 14.0:1. The factory O2 sensor is only good for tuning cruise/part throttle when you are targeting 14.7:1.
Dustin
Dustin
check autometers web site, there is a pdf file for you to download that shows the voltage graph.
