B18B1 Swap Questions And Rear Disc
Old Jul 21, 2009 | 12:25 AM
Ghettopoptart's Avatar
Default B18B1 Swap Questions And Rear Disc
Hi, i am new to the forum, and have used the search engine to the best of my knowledge, i got about 30% of my questions, answered. So i figured i'd ask them all here in one place and get the full detail.
I Today, bought a 92 Civic CX Hatch, has a D15 in it, slower than Christmas i'd say.
And in the past i owned a 94 HX hatch, with an LS b18b1 swap, although i did not do the swap, i loved the car as a daily, and the engines are fairly cheap to get around here. I am wanting to do the swap on this car as well. I have spoken to friends , and there seems to be some speculation to what exactly i will require in front of me to do the swap over the course of a weekend. Can someone give me the exact parts list i would need and of what year Integra i would need to Have them from? As in, B18b1 from a 93 integra, ect...
Also I would like to do a rear Disc brake conversion, the same lengthy detailed description of what i'd need and which year to get it from on what car.
Many apologies if i am just COMPLETELY overlooking things on the search engine, or if this has been answered plenty of times. Flaming is welcomed if that is so. Any help would be much appreciated!
-Paul
Old Jul 21, 2009 | 01:58 AM
Adam_b16a's Avatar
Default Re: B18B1 Swap Questions And Rear Disc
This should help somewhat.
https://honda-tech.com/forums/hybrid-engine-swaps-18/my-b20-into-ek-parts-list-504321/
Old Jul 21, 2009 | 07:57 PM
somewhat, exept it was for a b20, im doing an LS swap, also rear disc brake setup?
Old Jul 21, 2009 | 08:49 PM
Adam_b16a's Avatar
B20 and ls use the exact same components. They are almost the exact same motor.
Old Jul 22, 2009 | 09:00 AM
That i did not know. And any thing as far as the Rear disc brake setup?
Old Jul 22, 2009 | 11:02 AM
fireblaze2k1's Avatar
94-95 OBD1 Integra ECU (p75)
94-95 OBD1 Integra Intake Manifold
94-95 OBD1 Integra Axles/halfshaft
94-95 OBD1 Integra Or Stock Engine harness
94-95 OBD1 Integra T bracket
94-95 OBD1 Integra shift Linkage
94-95 OBD1 Integra Post Mount/Driverside mount
94-95 OBD1 Integra B18b1 Dizzy
Any B series Hydro Tansmission
Plus the B18 you're going to put in.
Old Jul 22, 2009 | 07:56 PM
eckoman_pdx's Avatar
For an Integra Rear Disc swap, you'll want the rear trailing arms (which should include the discs, calpiers, lines, and e-brake cables) from a 94-01 Integra RS or LS. I'd get them from a Teg that had no ABS (RS never had ABS).
You might want to get the proportioning valve from the same car too. Some people don't but I did when I did the conversion years ago.
CX's also have smaller front brakes than the Integras and Civic EX's did. I'd swap to the larger Integra front brakes while I was at it, and then swap in the larger Integra non-abs Brake Booster and non-abs MC.
If you want to use the smaller Civic Booster, you'll want to use a 91 EX MC.
Old Jul 23, 2009 | 09:22 AM
wow, thanks so much, haha , now hunting parts!
Old Jul 24, 2009 | 02:10 AM
You're welcome. I'm always glad to help Good luck with the project!!
Bluepitbull
Feb 8, 2012 04:47 PM
fast hatch
Suspension & Brakes
Nov 23, 2005 07:18 AM
disposable
Jun 18, 2005 09:16 PM
Kyo Babic
Mar 4, 2003 11:27 AM
djay86
Apr 10, 2002 11:01 AM
