B18B1 Swap Questions And Rear Disc
Hi, i am new to the forum, and have used the search engine to the best of my knowledge, i got about 30% of my questions, answered. So i figured i'd ask them all here in one place and get the full detail.
I Today, bought a 92 Civic CX Hatch, has a D15 in it, slower than Christmas i'd say.
And in the past i owned a 94 HX hatch, with an LS b18b1 swap, although i did not do the swap, i loved the car as a daily, and the engines are fairly cheap to get around here. I am wanting to do the swap on this car as well. I have spoken to friends , and there seems to be some speculation to what exactly i will require in front of me to do the swap over the course of a weekend. Can someone give me the exact parts list i would need and of what year Integra i would need to Have them from? As in, B18b1 from a 93 integra, ect...
Also I would like to do a rear Disc brake conversion, the same lengthy detailed description of what i'd need and which year to get it from on what car.
Many apologies if i am just COMPLETELY overlooking things on the search engine, or if this has been answered plenty of times. Flaming is welcomed if that is so. Any help would be much appreciated!
-Paul
-Paul
Re: B18B1 Swap Questions And Rear Disc
This should help somewhat.
https://honda-tech.com/forums/hybrid-engine-swaps-18/my-b20-into-ek-parts-list-504321/
94-95 OBD1 Integra ECU (p75)
94-95 OBD1 Integra Intake Manifold
94-95 OBD1 Integra Axles/halfshaft
94-95 OBD1 Integra Or Stock Engine harness
94-95 OBD1 Integra T bracket
94-95 OBD1 Integra shift Linkage
94-95 OBD1 Integra Post Mount/Driverside mount
94-95 OBD1 Integra B18b1 Dizzy
Any B series Hydro Tansmission
Plus the B18 you're going to put in.
For an Integra Rear Disc swap, you'll want the rear trailing arms (which should include the discs, calpiers, lines, and e-brake cables) from a 94-01 Integra RS or LS. I'd get them from a Teg that had no ABS (RS never had ABS).
You might want to get the proportioning valve from the same car too. Some people don't but I did when I did the conversion years ago.
CX's also have smaller front brakes than the Integras and Civic EX's did. I'd swap to the larger Integra front brakes while I was at it, and then swap in the larger Integra non-abs Brake Booster and non-abs MC.
If you want to use the smaller Civic Booster, you'll want to use a 91 EX MC.
Kyo Babic
03-04-2003 11:27 AM
