94 stock d16z6 weird problems
Old Jul 18, 2009 | 10:15 PM
krisc09's Avatar
Default 94 stock d16z6 weird problems
Well i'll give you what little background i have on the car. I bought it last week, in the ad it said it had an aem wideband, and all this other stuff that really didn't have anything to do with the motor. Well i got the car and it had the typical "idle problem" drove a couple hours to get it home, did some research about the fitv and the iacv. Replaced both of them after cleaning them up. The car still had the lumpy idle at start up. So i checked for vacuum leaks, couldn't find any. The car idles extremely low and nothing happens at all when i plug and unplug the iacv. i cant get my idle higher, but when driving around and i come to a stop it will just sit at either 1000-1200 no surging but if i put my foot behind the pedal i can lower my idle but it sits very very low almost dies. If i put ac on it dies unless i push pedal down. When i turn on my lights it will lower my idle pretty low as well. Also the aem wideband isnt on the car???? could that have anything to do with my problems? please help with anything you can im stuck. ima noob, any idea is better then what i have now
Old Jul 19, 2009 | 09:56 PM
krisc09's Avatar
Default Re: 94 stock d16z6 weird problems
please
Old Jul 19, 2009 | 10:17 PM
Ronstex's Avatar
Could try the idle screw on the throttle body. Also make sure your Coolant is all the way full.
Old Jul 20, 2009 | 10:15 AM
krisc09's Avatar
coolant is full, and idle screw doesnt make any difference unless its pushed all the way in it dies
Old Jul 20, 2009 | 01:38 PM
WootWootD16's Avatar
Check your mass air flow sensor, throttle positing sensor, and the o2 sensor..those would be my guess...possible bad injector, fuel filter..
Old Jul 20, 2009 | 01:55 PM
krisc09's Avatar
where is the maf, and the fuel coud cause the low idle, and what do i do about the iacv i hooked a good one up and it didnt make a difference when i plugged and unpllugged could it be a loose wire?
Former User's Avatar
Is the CEL ON?
You seem to have two separate problems:
1) The throttle cable is adjusted too tightly. It should have 3/8" to 1/2" free play.
2) The IACV is not working. Is the port leading to the IACV inside the throttle body clogged with gunk? Is the IACV getting battery voltage with the key in ON(II)?
Old Jul 20, 2009 | 02:33 PM
krisc09's Avatar
There is no check engine light on, but im thinkin he might of disconected those lights or something if possible i bought it off craigslist, thinkin it was a simple problem, i cleaned the iacv, and it sucks real hard from top hole when motor is running warmed up. and when i got the car the throttle cable had no slack at all, actually it was pulling a little imas go fix that right now.
Old Jul 20, 2009 | 02:38 PM
When you turn the key to ON(II), the CEL should illuminate for 2 seconds and then turn off. Some unscrupulous sellers will disable the CEL to hide problems. This is usually done by removing the CEL bulb from the cluster. Also check for a cut CEL wire at the rear of the cluster or the ECU connector.
Old Jul 20, 2009 | 02:57 PM
krisc09's Avatar
do you know what color it would be, and where my ecu is ? lol
sorry so many questions
Old Jul 20, 2009 | 03:13 PM
Color of what? Pull the cluster out and check whether the CEL bulb was removed
Behind the front passenger kick panel.
Old Jul 20, 2009 | 03:21 PM
krisc09's Avatar
alright, i apprecite all the help, ima go check all this right now.
Old Jul 20, 2009 | 03:58 PM
krisc09's Avatar
ok so the check engine light is on, i tried the paper clip thing and it didnt blink at all just stayed on, any suggestions
Old Jul 21, 2009 | 07:56 PM
krisc09's Avatar
anyone?
Old Jul 21, 2009 | 08:11 PM
40mpg_dx00's Avatar
sounds like a computer
94hondacivicvtec
Dec 7, 2008 12:44 AM
invasian_boy
Aug 28, 2007 06:08 PM
egme93
Sep 22, 2005 09:22 PM
JDM-EJ1
Oct 1, 2004 08:12 PM
SSS2000
May 11, 2004 04:21 PM
