question about crvtec
so i found this offer out in tampa and if i bought this from the guy what else would i need to make it a crvtec?
http://www.tamparacing.com/forums/ho...-gsr-head.html
um, a crv motor 2.0L.
that was just the a gsr head right? the block should come with all the vtec stuff...
u need a crv block,headgasker(crv),u might aswell get a b20 vtec golden eagle kit($200)
gsr head studs,oil pump and waterpump,and timing belt and the list goes on,,
some ppl will also tell u to change the pistons,rods and bearings and get better rod bolts(arp),so at the end u will spend a pretty penny ,,or u can just keep it simple and just place the vtec head and make sure to keep it at 7k rpms at the most ..
^^ if you want it to last, you will need to build it, they are ticking damn time bombs.
buy a ge vtec kit and and the pumps. to make it work, to make it right and have it last, you will need to do some internal work on the b20.
