95 Fog light problem. Searched.
Old Jul 18, 2009 | 09:44 AM
awdgsx96's Avatar
Default 95 Fog light problem. Searched.
Just installed my fogs yesterday. I wired them directly to my parking lights.
The passenger side works fine, however the driver side fog is grounding out. It is wired the same exact way as the passenger. It works sometimes, but once it touches something the wrong way, it blows blows the fuse out. The actual metal casing of the fog sparks. A couple of my friends said its' a common problem, I checked my grounds and they're good, as well as took the casing apart to check the ground inside the fog.
What they told me to do is put electrical tape and rubber washers in between the screws and the casing and mount but I'm afraid of a deeper electrical problem.
Any input is appreciated
Old Jul 20, 2009 | 05:34 AM
awdgsx96's Avatar
Default Re: 95 Fog light problem. Searched.
Nothing?
Not even a flame?
Old Jul 20, 2009 | 06:54 AM
wrestler72's Avatar
Did you check for any exposed wires?
Old Jul 20, 2009 | 09:17 AM
dxg4's Avatar
reversed polarity?.... you made the casing of the light hot, instead of ground.......? possibility.....or THERE IS A REVERSE SOMEWHERE in the lamp housing that is causing the casing to become hot.......
Old Jul 20, 2009 | 09:44 PM
awdgsx96's Avatar
Exposed wires were traced and covered.
I don't get the reverse polarity....the fogs were in a car right before mine and worked fine. That's the wierd part. But headlights worked fine even when the fog was on or when it grounded out.
Parking lights did go out though when it grounded and the fuse blew.
Old Jul 21, 2009 | 05:56 AM
dxg4's Avatar
do you know the maker of the lights and the model of the lights you have? and did you install a switch and relay for the lights? and what color were the wires you tapped to feed the lights?im looking at the schematics for the car and theres nothing to that circut(parking lights, cir#19)
Old Jul 21, 2009 | 06:38 AM
awdgsx96's Avatar
I believe they are just eBay lights. I'm not too sure. I really didn't look, I picked them up cheap.
The wiring is blue and black. The kid used gator clips to put them in with the parking lights. The same exact way he did on his old car which they were on, as well as his current car.
Edit: I'm not too sure what color the wires are that he tapped. It's raining, I'll have to check a little later
2.2accord
Mar 22, 2009 03:52 PM
96teggynonVtec
Sep 2, 2008 09:35 PM
treylittlet0n
Honda Civic (2006 - 2015)
Aug 18, 2007 05:01 PM
JDMegCoupe
26
May 12, 2006 05:52 PM
