Corner Light Problem
Old Mar 17, 2009 | 09:45 PM
2.2accord's Avatar
Default Corner Light Problem
Hi i have a 95 Accord. So i was driving around with my lights on and drove home took off my lights but then noticed the passenger corner light bulb the outter one was staying on, so when i turned my lights back on the driver side corner light doesn't turn on at all..anyone know what can be causing this problem?
Old Mar 17, 2009 | 10:05 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Corner Light Problem
Bad relay possibly?
Old Mar 17, 2009 | 10:12 PM
2.2accord's Avatar
i'm not sure..where would the relay be?
Old Mar 18, 2009 | 02:26 AM
dafang's Avatar
Check that you have the right bulb installed and that it is seated properly in socket. I had a similar problem from installing a bulb that looked right, but was not the right number.
Old Mar 18, 2009 | 06:53 AM
2.2accord's Avatar
it is the right bulb..i had those bulbs in for a while and everything worked properly until last night
Old Mar 18, 2009 | 08:20 AM
2.2accord's Avatar
i did install HID's last week but it was working fine when i put them in..also as i was cleaning the car yesterday i did notice the ground wire that goes from the engine mount to another screw on the body is broken in half..could that be the problem?
Old Mar 18, 2009 | 05:58 PM
2.2accord's Avatar
so i fixed the broken ground wire and lights still don't work, d/c my alarm and no lights, i tracked it down to the Cornering Light Control Unit..just don't know where it is? does anyone know?
Old Mar 18, 2009 | 09:16 PM
davey5300's Avatar
possibly be the turn signal relay??
Old Mar 18, 2009 | 11:26 PM
2.2accord's Avatar
nope, the relay is good
Old Mar 19, 2009 | 09:21 AM
jimbo24's Avatar
this is probably not the cause but you should check your fuses. hopefully this helps, if not, no harm done. good luck.
Old Mar 20, 2009 | 08:59 AM
2.2accord's Avatar
does anyone know where the wiper/blinker control unit is on a 95 accord? i have a 99.9 percent feeling it's the module because my intermittent wipers don't work, and my corners are messed
Old Mar 20, 2009 | 09:21 AM
billyrusa's Avatar
Have you checked the ground G301?
Old Mar 20, 2009 | 09:57 AM
ifxaccord's Avatar
New User
im having the same issue. The integrated control unit is on the interior fuse box on the driver kick panel. Mine was a big brown box, some are blue or white. I changed that and my combination switch and my corners and intermittent wipers still dont work. Checked all fuses. Im thinking its a bad ground or an open in the wire at this point. If you need a control unit I have 3 sitting as i kept trying different ones. If you get yours working let me know.
Old Mar 20, 2009 | 10:30 AM
2.2accord's Avatar
no i have not checked the ground G301...is it behind the driver or passenger headlamp?
ifxaccord: where are you located? i do see the big brown box but is that the unit? i was told the unit is located on the back of the fuse box
Old Mar 20, 2009 | 11:58 AM
billyrusa's Avatar
1. Driver side.
2. The integrated control unit is plugged on the fuse box. It is under the three relays and above all other wire harnesses and fuses.
Old Mar 20, 2009 | 01:38 PM
2.2accord's Avatar
billyrusa: is it the big brown box? about 4-5" wide and about 2-3 high? so it can either be the acutal brown box...or it can be the ground screw holding the module behind the driver side headlight?
Old Mar 20, 2009 | 05:55 PM
billyrusa's Avatar
Check the pic.
Old Mar 20, 2009 | 08:00 PM
ifxaccord's Avatar
New User
yea its the brown box. it could be that. i tired that and didnt solve my problem. could be a bad ground to the brown box or an open in a wire. Im located in NJ.
Old Mar 20, 2009 | 08:01 PM
ifxaccord's Avatar
New User
See attachment to test the integrated control unit. I think im having a bad ground. not sure still.
File Type: pdf
Old Mar 22, 2009 | 03:52 PM
ifxaccord's Avatar
New User
Check Fuse Number 37 in the under hood fuse box. Its the right row,3 down,7.5 amps. Let me know if that works. That controls the Integrated control unit.
Also Fuse number 6 and fuse 10 on the interior fuse box. 30 amp fuse is for integrated control unit.
rawrjaay
Aug 24, 2022 02:38 PM
robin-m
Honda CR-V & Element
Jun 19, 2014 06:25 PM
awdgsx96
Dec 26, 2009 12:58 PM
CPreston
Lighting
May 21, 2009 11:35 AM
LShatchie
26
Jun 29, 2005 03:21 AM
