Igination problem...need HELP fast.
i got an 88 civic..i put a new fuel filter,fuel pump, and igination switch,spark plug and wires. The car would just crank but wont start. Can anyone help me?
Thanks
Thanks
Just gotta keep checking off the fuel or spark list. For fuel check the injectors next. 88 civic....you got injectors right? If that doesn't work check the distributor cap and rotor. 88 civic....you got a distributor right? 88 civic....Thats old dude. lol
is it a Si model? remove your fuel return line and turn the key to the on position if no fuel comes out then you might have a bad Main relay or fuel pump.
Waldron Racing
Nov 26, 2013 06:45 AM
Projekt CR-X
25
Mar 8, 2011 08:13 PM
EFb18b
Aug 17, 2009 11:18 AM
JolToN49
Nov 20, 2002 11:41 AM
