crankcase venting......i think its cuzing my oil leaks.
Old Jul 14, 2009 | 07:47 PM
si90rex's Avatar
Default crankcase venting......i think its cuzing my oil leaks.
New ls/vtec having problems with oil pan not sealing. i replaced the oil pan 2twice and and put three gaskets on. one with no gasket sealer, one with lil sealer and one with everything sealed. im using the stock ventilation setup...12 to 1 comp. can any one help.
thanks
Old Jul 15, 2009 | 11:39 AM
si90rex's Avatar
Default Re: crankcase venting......i think its cuzing my oil leaks.
bump
Old Jul 15, 2009 | 01:42 PM
flesh199's Avatar
catch can time my friend...
Old Jul 15, 2009 | 02:31 PM
gettin it's Avatar
Yes sirrr! I had the same problem bro. You need to get a can of your choice, and port the back of the block with either t1r can setup, or a moroso can setup, or endyne can setup. Or fab a can setup of your choice. The thread is on here, shouldnt be to many pages back. Do a little searching and you will see and get the part numbers for the fittings from honda. Good luck.
Old Jul 15, 2009 | 04:42 PM
OH_1fstgsr's Avatar
This is in the marketplace. There is some good information and examples.
https://honda-tech.com/forums/forced-induction-49/new-anodized-polished-catch-can-kits-2020423/
Old Jul 16, 2009 | 03:30 PM
si90rex's Avatar
Y a catch can? y not the check vavle into a the exhaust?
PNK SLP
14
Jan 20, 2009 10:51 PM
Will_H
Dec 1, 2007 07:14 AM
luvsspeed
Sep 17, 2006 06:49 PM
EJ8chu
Sep 14, 2006 09:40 PM
92ehatch
17
Nov 25, 2005 12:30 AM
