Wideband and Narrow Band in one O2 Sensor
Old Jul 14, 2009 | 06:21 PM
cmdeoro's Avatar
Icon2 Wideband and Narrow Band in one O2 Sensor
I just bought my EF with a poor mans Type R. The problem is that the guy I bought the car from converted it to OBD0 and I am trying to convert it to OBD1. The reason for me to convert it to OBD1 is so that I can tune it with Hondata S300. I know I need a 4 wire O2 Sensor for the conversion but I also need a Wideband O2 Sensor. I have heard that there are wideband O2 sensors that have extra wires so that it can send the narrow band reading to the ECU. Is this possible and if it is can I use this? Where can I get it?
Old Jul 14, 2009 | 06:25 PM
93turbo16's Avatar
Default Re: Wideband and Narrow Band in one O2 Sensor
Almost all of them have two analog outputs. One to simulate the narrowband 0-1v and the other is the 0-5v wideband output.
You can just disable the 02 sensor heater in the S300 and use the wideband for both.
Old Jul 14, 2009 | 06:57 PM
cmdeoro's Avatar
So basically, I can just run those 2 analog wires to the ecu and then run the other wideband to the meter/ gauge. What brand do you recommend?
Old Jul 14, 2009 | 09:11 PM
Sl1ck09's Avatar
i have the aem 30-4100 and im trying to figure if i to can just use the wideband alone or do i need to have my stock o2 sensor in 2. like you said i could just disable my stock o2 and just run my 30-4100 and just make sure that is hooked up to my s300? and if so how do i hook this up to my s300. im running obd 1 sorry to thread jack
Old Jul 14, 2009 | 09:28 PM
cmdeoro's Avatar
Don't be sorry thats exactly what I am asking.
Old Jul 15, 2009 | 07:54 AM
Rtype16's Avatar
The 30-4100 has two outputs. one is the 0-5 and the other is the 0-1 you can hook both up to the Hondata I beleive. You may want to give them on their tech support and they will tell you exactly how to hook it up and what calibration to use for the sensor.
Old Jul 15, 2009 | 08:17 AM
93turbo16's Avatar
I actually like the LC1.. but it doesn't have a gauge. You can add a gauge to it but it would use one of the analog output wires from the LC1 to run it.
If you are looking at something with a gauge and two outputs I would look into the PLX units.
Old Jul 15, 2009 | 03:36 PM
Sl1ck09's Avatar
so this is my setup right now. i took my o2 sensor out and i put in my 30-4100 in. i left my o2 sensor tied up for now still pluged connected. and now all i need to do it just make sure my 0-5v is connected.? or do i have to remove my stock o2 sensor and run my 0-5v into my stock o2 harness? hope this aint to confusing best way i could think of writing it
DC2R96
Feb 11, 2011 02:17 PM
cmdeoro
Engine Management and Tuning
17
Jul 29, 2009 08:00 AM
EF9ZC
Mar 28, 2006 10:48 AM
rice4life
Jun 26, 2003 03:39 PM
Norcalstoppy
Aug 4, 2002 09:33 AM
