hooking up a heated O2 sensor to an OBD0 car
Old Jun 14, 2002 | 06:56 PM
rice4life's Avatar
Default hooking up a heated O2 sensor to an OBD0 car
how can i hook up a heated 02 sensor to a non-obd ecu. the closest i can put my O2 sensor is on the downpipe close to the turbo. my sensor is not giving correct reading because it's not hot enought. only when i drive my car hard and the O2 gets hot enought to give right reading. can i just hook a heated O2 sensor to an ignition relay or does the ecu control amount of heat of the O2 sensor in OBD1.
Old Jun 26, 2003 | 03:39 PM
2 0 3's Avatar
Default Re: hooking up a heated O2 sensor to an OBD0 car (rice4life)
sorry to say but no you cant, im trying to do the same thing.
- are you using a obd0 ecu ?
read this it may help explain... https://honda-tech.com/zerothread?id=545609
rice4life
Jan 13, 2008 08:23 AM
EF9ZC
Mar 28, 2006 10:48 AM
Nisif
Mar 16, 2005 08:53 PM
