What yall think about this simple set up?
GSR Motor
Type R cams
Competition Clutch
skunk 2 68mm throttle body
skunk2 intake manifold
AEM Cam Gears
OMNI power Dual valve springs and retainers
t3/t4 .57 trim turbo
drag a/c compatible manifold
750 rc injectors
Tuned on AEM FIC on 10lbs
Type R cams
Competition Clutch
AEM Cam Gears
750 rc injectors
shoud be good to go. mabey swap out the drag manifold later. there was some trouble with the rc750's a while back, are yours saturated or peak and hold?
look here for other gsr set-ups: https://honda-tech.com/forums/forced-induction-16/post-your-turbo-gsr-hp-numbers-1501150/
looks fine to me. if you have that setup up and running with the tune, how about YOU give us some ideas about what you think about the setup.
SomeDude56
Feb 2, 2006 09:43 PM
