Exhaust smells like burnt popcorn, at idle smells sweet
Exhaust side smells like burnt popcorn, at idle the interior smells sweet.
Milled head around 11.8:1 compression, with Comptech 4-2-1 header, Spoon N1, 16 degrees timing at the distributor, B&M fuel modifier bumped to 52PSI, everything else stock. B18C5 motor.
Never like this until I started modifying.
Any ideas? Possibly a high flow cat is in order?
[Modified by Edwin, 12:42 AM 8/23/2002]
burnt popcorn is probably just a lil oil burning
the sweet smell though u might want to check out ur radiator cause usually a sweet smell is radiator fluid
What you're smelling is burning Rice. LOL
Seriously though, when one of my ricer friends put a huge can on his Civic, it smelled like fried doughnuts.
Edwin, my exhaust smells after use as well... I thought it is just because the unit is new. If you want, come over, take a SMELL... if it’s the same odor then it’s the exhaust and not the monster you have camouflaged under the hood.
Thanks for the replies guys, I will have to check all the fluid levels tomorrow to rule those things out. No leaks anywhere to be found.
murmur9
26
May 18, 2004 07:01 PM
imnotswapped
Oct 12, 2003 10:06 AM
Ri5e
Mar 30, 2002 03:57 PM
