Carb'd Honda Ignition System
Both were factory originally. Just the module increased consistency. Adding the "hot" coil, increasing spark plug gap, and retiming a little gave NOTICEABLY better bottom end torque. Keep in mind- both were trucks which were used for towing. Did the super light springs in the Dodge- worked great- like an old 340 accelerating; but towing it was too much and had to compensate w/ a medium spring. Anyway I digress- the spark color went from yellow/orange to the whitest I'd seen and grounding the spark through a screwdriver to engine would arc at least an inch. Also had to change carb a little.
vaporboy12
Oct 12, 2004 09:59 AM
