My Seatbelts Don't Budge
Old Jul 11, 2009 | 09:54 AM
tweek_boii's Avatar
Icon6 My Seatbelts Don't Budge
My seatbelts do not budge. You know how when you press your brakes, they lock? Well mine stayed locked both passenger and driver. Even with no battery. Any help ?
My girlfriends mom who is big can't put on the seatbelt lol. help ?
Old Jul 11, 2009 | 10:15 AM
mugen88crx's Avatar
Default Re: My Seatbelts Don't Budge
Go to the dealer, all SRS/safety related items should be covered.
Old Jul 11, 2009 | 10:35 AM
tweek_boii's Avatar
I bought my car crashed, all the airbags have been deployed..
If I got to the dealer to fix this srs problem, I'm scared they will first slap me fallowed by a recommendation for installing airbags again
Old Jul 11, 2009 | 10:42 AM
mugen88crx's Avatar
If the airbags deployed then you have to replace the belt & tensioner as well, along with the crash sensors. Trust me I know, I work for a dealer doing wholesale with body shops all day long. The body shop should have replaced at the very minimum the airbag, belt & tensioner and if the SRS light was still on then the crash sensors as well. Go back to the body shop you had it done at, it's their problem not yours. Raise hell if need be.
Misread: I saw you said you BOUGHT it crashed!? WOW. Um? I guess try to cop your insurance into replacing the belts & tensioners. If not you'll have to fork over the money. Once those things lock from a crash there is no turning back.
Old Jul 11, 2009 | 11:28 AM
tweek_boii's Avatar
I didn't fix it a shop, I worked on it .. Put the front bumper sensors again..
So my belts are for ever jammed ?
Is it time for some recaros with some takatas ?? :/
Old Jul 11, 2009 | 01:00 PM
mugen88crx's Avatar
If the airbags deployed and the sensor went off then yes your seatbelts are forever jammed. List price on new belt & retractor assemblies for a 2004 RSX are $343.68 EACH!!! It's also a "controlled" part which means the dealer would have to order them according to your specific VIN.
"Is it time for some recaros with some takatas ?? :/ " - I would prob go this route! Just hope if you ever sell it, it's to a race inspired Honda fan.
Old Jul 11, 2009 | 01:09 PM
tweek_boii's Avatar
You are very smart, I would never think of that.. I will be keeping this car till it dies. So in this case recaros wont be a bad idea..
Old Jul 12, 2009 | 11:26 AM
sohckid00's Avatar
sorry for stealing your topic but im going to get used driver side seatbelts( male female end only) from an 03 rsx type s and i have an 04 base model would it work to turn off my srs light...i got an airbag tech to look at it and he said that was the problem along with the srs module. the serial # has to be the exact to work correct? the 03 rsx type s is a race car so not a crashed buy. anyway thanx for your time. mugen88crx
Old Jul 13, 2009 | 09:48 AM
mugen88crx's Avatar
The belts, opds unit and SRS unit are the same for an 03 RSX-S and a 04 RSX Base. Same part numbers. As long as the parts your putting in arn't fualty (from a wrecked car) they should all work together, just have a dealer clear the code.
Old Jul 13, 2009 | 09:53 AM
josh's ep3's Avatar
Function > Form
Damn, seatbelts are hardcore lol.
Old Jul 13, 2009 | 07:31 PM
sohckid00's Avatar
thanx bro i appreciate the help. and the srs module has to be the same # because mine is one # off from the the guy im getting the parts from. so would it work or not? thanx again i got screwed by a used car dealer here in cali and can't get my car registered until i get the srs code cleared ><
Old Jul 14, 2009 | 05:14 AM
turboteg2nv's Avatar
I would not recommend using 4 or 5pt harnesses in a daily driven car. Without a full roll cage and proper mounting points, a 4pt or 5pt harness will not allow you to move during a crash which can break your neck/back.
Old Jul 16, 2009 | 12:42 AM
superspeed's Avatar
so if my ep3 passenger airbag deploys do i have to replace all the seat belts on the front? can i get it used?
CrankyAmps
Apr 14, 2017 04:06 PM
drummerman2008
Honda Civic (2001 - 2005)
Nov 17, 2012 07:32 PM
S_1984
Sep 4, 2010 10:01 AM
95civhb
Jan 1, 2008 10:55 PM
tunerdude
Jan 23, 2006 08:20 PM
