Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
need some help... technical problems..
Old Dec 30, 2007 | 10:10 AM
95civhb's Avatar
Default need some help... technical problems..
got a 2001 civic dx-g...
the timing belt was changed, and the alternator light came on.. they checked out the alternator (replaced it) but that was not the problem...
the garage then disconnected the alternator light and installed a voltage gauge in the car to monitor the amps..
the srs light then came on, and is still on.. They disconnected the airbag, and the light is still on ...
all of this after the timing belt was replaced... any thoughts??
thanks!
Old Dec 30, 2007 | 10:47 AM
JimmyM86's Avatar
Default Re: need some help... technical problems.. (95civhb)
https://honda-tech.com/zerothread?id=2128335
Found this in the FAQ's...reading this should show you how to reset your SRS light. Just an idea, but you may want to have the shop hook your air bag back up!
Hope this helps.
Old Dec 30, 2007 | 10:20 PM
95civhb's Avatar
Default Re: need some help... technical problems.. (JimmyM86)
thanks for the help!
anyone have any ideas on the altenator check light??
Old Dec 30, 2007 | 11:57 PM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civhb &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the help!
anyone have any ideas on the altenator check light?? </TD></TR></TABLE>
You can get the codes cleared at AutoZone.
Old Dec 31, 2007 | 03:31 AM
AccordEX1991's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civhb &raquo;</TD></TR><TR><TD CLASS="quote">got a 2001 civic dx-g...
thanks! </TD></TR></TABLE>
After a timing belt change, my srs light also came on. I just kept driving it and it reset after about 5 miles of driving.
Old Dec 31, 2007 | 12:36 PM
JDM_ESK1's Avatar
Reason your light probably came on was because the Belt was not tightened enough when reinstalled. You probably replaced the alternator for no reason, and disconnecting the alternator light probably will cause a lot more problems for you in the future.
You do not use a voltage gauge to monitor amps, it just shows you the volt reading.
Reconnect your airbag, your alternator light, and have your mechanic.. actually bring it to another mechanic and get the belt put on properly.
The reason your SRS light turned on is because the alternator is not putting out the proper output to power your electrical system making the SRS ecu think there is problem.
Old Jan 1, 2008 | 10:55 PM
95civhb's Avatar
Default Re: (JDM_ESK1)
thank you! I will give that a try..
mimog3
Oct 6, 2014 09:29 AM
amerdsp
Aug 9, 2012 05:33 AM
Stangracer85
Classic Hondas
Nov 21, 2009 08:26 PM
zcivicz
Dec 5, 2005 10:44 AM
