ANY 10-11 SECOND NITROUS SETUPS?
Old Jul 10, 2009 | 05:25 PM
JDM91EF2's Avatar
Icon3 ANY 10-11 SECOND NITROUS SETUPS?
I'LL POST UP MY OLD SETUP LATER CAN I SEE SOME OTHER ONES??
ET
MPH
60 FOOT
HP/TQ??
Old Jul 10, 2009 | 05:41 PM
miniturboteg's Avatar
Default Re: ANY 10-11 SECOND NITROUS SETUPS?
also interested, dnt c/hear many hondas with big nitrous setups..
Old Jul 10, 2009 | 06:02 PM
gtistile's Avatar
I was running a simple single nozzle 100 shot dry on my stock K20 hatch. 1/8th mile times said it was good for a LOW 11. plan was to bump it to 150 and shoot for 10s, then it got stolen.
Consistent 1.6 60fts on 24.5s spraying off the line. with more seat time had 1.5s easy
Old Jul 10, 2009 | 06:11 PM
EM2Civic's Avatar
Same here with a horrible alignment/caster all ****ed on a 100 shot with my K20eg, I was trapping as high as 120 on drag radials best time of 12.0 on radials 2.0 60ft :S :S.
I know of a couple K20's hatches running 200 shot on 100% stock bottom ends running mid 10s.
Old Jul 10, 2009 | 06:15 PM
Garage 808 Hatch's Avatar
I went 11.13 @ 122.51 on an 11.5:1 B16, with old crower 3's, AEBS cheap IM, 68mm TB, Modified DC header and a 125 shot single fogger. car made 181/115 all motor and 281/220 on spray
Old Jul 10, 2009 | 08:20 PM
JDM91EF2's Avatar
DAMN THAT WAS IN YOUR EF RIGHT? I READ YOUR OTHER POSTS...
DID U SPRAY OFF THE LINE?
WHAT YOU THINK ABOUT A 14:1 MOTOR ON A B20 WITH STOCK SLEEVES WITH A BLOCKGAURD AND A 100 SHOT ON EAGLE RODS??
Old Jul 10, 2009 | 09:53 PM
91redteg's Avatar
sounds like a recipe for crackedsleeves
Old Jul 10, 2009 | 10:19 PM
jjspec's Avatar
10.600 @ 133 on an stock sleeve H22, Mahle high comp pistons, eagle rods, stock ecu, 2200 lb car with 26 talls and a 240 shot. Back in '06
Old Jul 10, 2009 | 10:51 PM
jnv255's Avatar
I thought u sprayed more than a 240 Jimmy
Old Jul 11, 2009 | 02:17 AM
wolve's Avatar
had a 11.7-11.8@120-121mph setup under my ***
made 1 foolish mistake and it blew up on the dyno
drove the times in my sig with street tires
have slicks/tractiionbar ready to go in but my motor let go
totally stock b18cr on a progressive 150
Old Jul 11, 2009 | 02:32 AM
lou-tdi's Avatar
Wolve, sorry to here that, I was looking forward to seeing your car again. What happened to the motor?
DONT GIVE UP!
Old Jul 11, 2009 | 09:47 AM
jjspec's Avatar
You are correct. I started out at 400, but figured out a lot about the setup and started over at 240 and it went faster. The season ended and I built the Hot Rod before I had much time to experiment. I am sure it would have went deep nines on the 400 but we will never know.
Old Jul 11, 2009 | 10:30 AM
.CUBISH.'s Avatar
i went 10.69@136 mph in a 2400lbs street car back in 04-05
2.0 b-series making mid 400's on spray
Old Jul 11, 2009 | 11:21 AM
hello1320's Avatar
2.0 vtec ,sleeves, direct port fogger made 189/142 off 378/311 with spray went 7.0 in the 1/8@109 never took it to the 1/4
Old Jul 12, 2009 | 09:02 AM
lou-tdi's Avatar
F2K EG with progressive nitrous coming soon!
Old Jul 12, 2009 | 12:40 PM
JDM91EF2's Avatar
...OUR SHOP/STREET CRX HAS A B20 VTEC ON 150 SHOT STOCK SLEEVES, 11:1 FLAT TOP PISTONS AND MADE 425/385 TQ @ CHURCHS AUTOMOTIVE..
CAR WENT 10.68 @ 132...
Old Jul 12, 2009 | 02:03 PM
hopefully soon we have the blue shop crx running. 85mm GSR, dual stage nitrous. shooting for 400whp in a 1700lb car
Old Jul 12, 2009 | 10:03 PM
bauergold's Avatar
Nitrous hondas FTW!
More people need to build them.
Old Jul 12, 2009 | 11:11 PM
hello1320's Avatar
r u guys talkin about nitrous ONLY!!!!!!!!! please clarify
Old Jul 13, 2009 | 06:12 AM
661rex89si's Avatar
duh !!!!!! pay attention brotha
Old Jul 13, 2009 | 06:43 AM
sgnlab's Avatar
http://www.youtube.com/watch?v=rQYVbzV4VTM
11.3 on a stock k series with 125 shot of juice! 1.5 60ft
Old Jul 13, 2009 | 08:20 AM
ghostofnyc's Avatar
h2b ek on a dual stage 75 shot 1st and 2nd gear 75+125 shot 3rd and 4th 10.** @ 140mph. traction issues
Old Jul 13, 2009 | 08:59 AM
wolve's Avatar
DONT GIVE UP!
failures are not a reason for quitting, just reasons for stepping up your game
next season a 87.2mm piston/rod combo on stock sleeves with some cams
aiming for 400-450whp on spray and high 10's in my daily driver (320whp is so 2008)
i'll back in Santa Pod next year for at least 1 event (maybe HKS class if the rules are'nt to harsh )
Old Jul 13, 2009 | 09:20 AM
lou-tdi's Avatar
Gotta love your attitude towards it! keep me updated, cant wait to see it!
Old Jul 13, 2009 | 09:57 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
if you have to ask us what will work, chances are you are uneducated by the compression you are wanting to run, the skimpy block guard and probably stock cast pistons..
so no, i highly doubt this setup would last long
