ANY 10-11 SECOND NITROUS SETUPS?
#201
Re: ANY 10-11 SECOND NITROUS SETUPS?
#202
well i finished up the setup and it was a bittersweet dyno session lol.
-Stock GSR motor (except head studs)
-Custom header (4 into 3in collector to 3in exhaust)
-Walbro 255 pump
-RC 1000cc injectors
-Hondata S300
-Tuned on pump E85
-Dual stage dry shot (controled by the hondata in three stages)
-Made 164hp on the motor.
the setup worked out great, it made good power but i screwed up on the last pass of the day and forgot to adjust the timing on the second stage so it hurt quite a bit. there was all sorts of preignition going on pitted up the pistons pretty good, BUT the good news is that it drove home
i was trying to rush cuz there were some guys waiting to get on the dyno behind me and i just made a dumb oversight. on the final pull which was the 150 shot it made 330 at 6500 rpm but it was spinning on the dyno so we let out and the damage was done. looked over the tables and almost instantly saw my screw up. if i had not made the dumb mistake, i see no reason why it couldn't take even more than the 150 on the stock motor. we started out with a 40 shot then a 80, then a 120, then went back down to a 50 because we had to change the jets in both stages from 40 and 80 to 50 and 100...and since i was running low on time i decided to go straight to the 150 from there and thats where i made my error. im putting another stocker back in and gonna hit the dyno again to finish it up. here are a few pictures of the car and setup and a video of the dyno session.
http://www.youtube.com/watch?v=4-6AA...e_gdata_player
-Walbro 255 pump
-Hondata S300
-Tuned on pump E85
#203
-Walbro 255 pump
-Hondata S300
-Tuned on pump E85
-Walbro 255 pump
-Hondata S300
-Tuned on pump E85
Good luck with it man, and as always cool little video to go along with the post.
In 1998 I installed a 60hp dry shot on a 1997 Civic EX. I have no clue how I did not kill that engine because I never adjusted the timing or anything with that setup. I came close to killing the engine on a pull against a Mustang, but luckily the plug melted and made it out of the engine before anything else was damaged. That engine lived a long tough life, it had well over 100k tough miles before it finally spun a rod bearing.
#205
K eg nitrous in car cam 10 sec pass
http://www.youtube.com/watch?v=AKN0H...e_gdata_player
http://www.youtube.com/watch?v=TyPye3zwJhg&sns=em
#206
**** ups can be costly with nitrous, blew cil#2 once like that to...
i always triple check my timing now... once encountered a typo on the third check... 7 degrees advance instead of retard... that would've been a boom too!
good luck with the next stocker!!!
#207
great simple setup! very nicely done and excecuted!
yeah i was stoked about how the car did but pretty disappointed in how i did lol. im usually very meticulous about that stuff. i dont think ive ever made a dumb mistake like that on any of the turbo cars ive done. it was just a combination of being in a rush and getting over confident that i had everything in order cuz everything was going so smoothly. I'll hopefully be able to post track video of the next motor.
#209
thanks! i tried to keep it as simple but, based on what I read and researched, as logical as possible. it was really tough to sort through all of the bad advice on forums and websites to find the good advice lol. I'm pretty sure your posts on here were some of the more helpful ones so I'm glad you approve lol.
#210
As far as advice on nitrous setups. I am not sure how much this will help you, but there are some forums out there where there are some really fast nitrous V8 guys who may be able to give you some tuning advice for a nitrous engine. I certainly do not have any useful info for tuning a nitrous engine, but maybe the yellowbullet.com may have some. Guys running in the 4's through the 1/8th on 275 drag radials is certainly impressive to me and many are doing it with nitrous small blocks now. Not sure how helpful any of them would be on that forum or if you could find anything worth while on there, but it was a thought.....
This is true.
#211
no, you are right, that site is very useful. there are some really smart guys in there. people on there don't respond well to direct questions but there is still tons of info to be had by just browsing and inferring a lot from conversations on there. I ended up getting most of my info from domestic guys or locals that work with nitrous domestics. even among domestic guys the info varies. I tried my best to get ahold of guys like Richewerks who were having success with nitrous specifically on Honda motors, but it seems all the people having success with it are extremely hard to get a hold of lol. it's understandable though cuz I'm sure they get tons of questions on a weekly basis. I didn't want to pester them, I know how that feels so I founds info elsewhere those guys definitely have that **** figured out though.
#212
Biggest thing he says is to keep the plug as clean as possible. He tunes nitrous cars to around the same a/f that they run on motor. Running lean is not likely to hurt a motor, no matter what everyone tells you. However running too much timing or being too rich will definitely create too much heat and melt some aluminum. lol
#213
Check out any post by monte smith on there. I would consider him to be the nitrous god. He isn't someone who just restates what other people have said. He has decades of experience and definitely knows what he is talking about.
Over here in the south there is a ton of grudge racing all the time. Tons of the cars and bikes are still nitrous setups and many of them are the fastest street cars and bikes on the planet. At one point I thought that nitrous setups would die down a little since the technology with the blowers and turbos has progressed a lot. That is not the case, or so it seems on my end over here. One person I would really like to talk to if I ever built a nitrous small block would be Billy Glidden. I am still amazed at his outlaw 10.5" car that went 4.0's on a Ford small block that was under 330ci, cast intake manifold, single carb, and 2 stages.
#214
Nitrous is fun though and great for grudge racing.
Billy Glidden definitely knows whats up that's for sure.
#215
I heard that at one of the tracks down here that the Pro Mod cars were banned from purging through the engine at one point, but I'm not totally sure on that rule.
Here is a car from my neck of the woods. Small block Mustang on a 275, has went a best of 4.70's in the 1/8th and went 4.90's on this particular pass. You can watch him purge both through the engine and into the atmosphere. I always heard that purging into the engine was the best way to clean the plugs just before a pass.
http://youtu.be/caYnaXk1XcI
#220
https://www.youtube.com/watch?v=y1BjzIb5tmU
Friend of mines 10 second nitrous hatch, simple ish 84x89 on a small shot of dope, excuse the meemaw shifting, he is aware of his mediocre driving skill set.
#221
I went 1070 at 131 6 years ago. Getting ready to bring the car back out. I popped a head gasket around the 1/8 mile and was spitting all the way threw the traps. That was with a 175 direct port dry shot with fuel added threw the injectors. Motor is a b series 2.1L 11 and half to one compression. It had stage one web cams with a stock type r intake and full exhaust threw the muffler. The car weighed 2460 with me in it. B16 trans didn't have traction bar but had a 1.5 60. Motor
made over 400. But I learned a lot 175 is to much out the hole. 125 shot is perfect. The radiator was clogged up witch I just found out last summer because I put a new one in and gave it to my nephew to put in his daily and it blew and head gasket. Changes since then I put a traction bar on it. I did two shots dry. 125 125. The car does not weigh no where near what it did. I shooting for 1800. And this time my tuner is going to come with me to the track. I also had the valves over sized and put web stage three cams in it. I have been building this car for years. Iam hoping to get to the track in the nexted two months and I plan on going into the 9s. When I said that when I first started out people said I was crazy but times have changed Old pictures
#222
-Walbro 255 pump
-Hondata S300
-Tuned on pump E85
-Walbro 255 pump
-Hondata S300
-Tuned on pump E85
PS: I shoot (video) as well - mostly with drones.
#223
New setup sounds awesome. Should run easy 9s with some seat time.
When are you planning on making it to the track?
#225
^Awesome!
My new setup should be pretty fun.
H23A - 220whp on motor - 340whp on nitrous. Motor is in a gutted and cut eg sedan.
Aiming for 10s on the nitrous.
GSRontheBottle
11-25-2002 09:59 PM
