d15 mini me swap
Old Jul 9, 2009 | 11:07 PM
trickster kid's Avatar
Default d15 mini me swap
Ok. before I get flamed for not knowing I'll tell you I dont know.
I'm about to embark on a mini me swap journey. I have read the swap tut here in the FAQ section about a dozen times so dont refer me to that.
I need to know EXACTLY, EVERY PART I will need for this swap. I know I need the Cylinder Head, Distributor cap and rotor, I'm changing the intake manifold, timing belt water pump, valve cover, spark plugs, spark plug wires. I'm also replacing the head gaskets. do I need fuel injectors? The tut says most of the above and etc. I want to know whats in the etc part.
Thanks guys and gals
Old Jul 9, 2009 | 11:32 PM
sp00ledbseries's Avatar
Default Re: d15 mini me swap
Looks like you got what you need besides a ecu. Have to wire in vtec too. Dont forget to pull the jet in the block
Old Jul 9, 2009 | 11:34 PM
ok. simply for my own clarification. what I have listed up there including fuel injectors, vtec solenoid, the p28 ecu and pulling the oil jet is all I will need?
What will be necessary to wire the vtec?
Old Jul 9, 2009 | 11:39 PM
google search for vtec wiring diagram. There all hundreds of threads on this
Old Jul 9, 2009 | 11:49 PM
thanks for the info bud. this can be locked now
sony224422
Sep 25, 2015 10:50 AM
HondaCivGirl
Mar 11, 2011 12:34 PM
freddysEF
Jan 28, 2007 12:15 AM
eg686
Jun 26, 2005 12:32 AM
iHave2Cams
Feb 17, 2004 05:53 PM
