wideband hookup to chipped ecu?
Old Jul 9, 2009 | 03:05 PM
Honda4life777's Avatar
Icon2 wideband hookup to chipped ecu?
I just ordered a glowshift wideband kit (gauge,control unit and bosch 4.9 sensor) . How do I hook it up to my chipped p28 ecu so I can get readings to go to my ecu control datalog program?
Old Jul 9, 2009 | 03:26 PM
HRTuning's Avatar
Default Re: wideband hookup to chipped ecu?
If you're using crome you're limited to using the O2 input. Otherwise you have ELD, B6, and EGR Lift as options as well. Output of the wideband goes to the input you choose.
Old Jul 9, 2009 | 03:38 PM
I dont know what eld and b6 are.
I am using the free crome to tune. I will be using ecu control and/or freelog to do datalogging. So I hook the wideband 5v wire to the stock o2 signal wire? Does the datalogging software convert the voltage signal?
Old Jul 9, 2009 | 03:40 PM
Do I use the stock o2 or does the wideband replace it?
Old Jul 9, 2009 | 03:50 PM
I CRX I's Avatar
pgmfi.org, read read and read some more. its in there
Old Jul 9, 2009 | 03:57 PM
Ya I am sure it is in there somewhere, thanks for the tip smart ***. Insted of searching for hours, how about i just ask a question on the good ol h-t? sounds like a normal thing to do.
Old Jul 9, 2009 | 04:55 PM
unusual71's Avatar
basically. make the ecu run in Open Loop all the time (stock narrowband 02 disabled) by changing the tune.
hook up some sort of 0-5V output (dont know for your specific apparatus) of the wideband into the stock 02 signal (D14 in ecu plug, white wire)
perform this modification to the ECU if you want 0-5V resolution instead of 3.8V that the ecu can normally handle. this modification also stabilizes the signal as it goes through the ecu
http://forum.pgmfi.org/viewtopic.php...a&hilit=5v+mod
Then adjust your settings in free log to read for a wideband O2 sensor and your set.
add a 4 pin header to the ecu, or have you already. Then you need a cable to convert serial to USB, pretty much any type can be used
here are some more informations
http://www.d-series.org/forums/diy-f...e-freelog.html
Old Jul 10, 2009 | 06:06 PM
I CRX I's Avatar
Originally Posted by Honda4life777
Ya I am sure it is in there somewhere, thanks for the tip smart ***. Insted of searching for hours, how about i just act like a lazy dumb *** and hope somebody spoon feeds me info i can easily find myself if i did a little searcing...
now be a good boy and eat your num num but next time, before calling somebody a smart ***....try to do a little searching rather than wasting internet bandwidth with questions that have been thoroughly covered over and over again...thanks
variable
Engine Management and Tuning
Oct 16, 2009 01:59 PM
lightningfastlude
Oct 13, 2007 07:40 AM
sanfriz
Mar 26, 2006 11:06 PM
planeman01
Mar 18, 2006 01:32 PM
Soccerking3000
Mar 22, 2005 04:23 PM
