Speedo Jumping all over the place
So my speedo tonight just decided to take a crap everytime i floor it. THen afterwards it just jumps around eveyr so often or just goes back to zero. I could be driving then itll jump up and down and sometimes zero.
vss going bad? wiring somewhere?
Does the motor stutter with it? If so, more than likely it is the distributor. The ignitor module goes out in them and they go all over the place. If not try the fuses. Or get a buddies dizzy to cross-reference.
its probably the connector to the vehicle speed sensor. unplug it and clean out the connectors. it can get pretty corroded in there. mine did same thing, cleaned it, now it works good. vss is located on rear of tranny. plug goes in close to where the cv shafts come out of the tranny.
smokinsi
10
Sep 1, 2004 08:43 AM
