93 civic IAT and O2 sensor problem
Hi
Today we checked the CEL and it said IAT sensor signal high and O2 sensor heater problem.
So should i replace both sensors to fix this problem?
And also where is IAT sensor located exactly?
Thank you
Thank you
What engine?
IAT can be cleaned but it might need replaced. B16's have them on the intake pipe. B18's are in the intake manifold runner just before the head. Not sure about D-series.
www.hondapartsdeals.com has nice factory schematics to track it down.
Replace the O2....
www.rockauto.com has excellent prices.
GL OP
Replace the O2....
GL OP
What engine?
Replace the O2....
GL OP
Replace the O2....
GL OP
Run through the troubleshooting first before you spend money on new sensors as it could be a wiring problem.
It may not be the sensors themselves... I posted troubleshooting flow charts for the IAT in this thread https://honda-tech.com/forums/showthread.php?t=2602702
I see on the d16y7, the IAT sensor is near the air filter. I have short ram on mine... so could it be that i don't have IAT sensor not plugged and hiding somewhere?
It is #11 in the picture below.
o ok ok... i'll check it out~ and if i want to clean the IAT sensor? do i just clean out the plug? what kind of cleaner should i use?
wtf its on the back of the manifold? ive never seen it there lol. But ya i suggest you get a new one if your one is giving you a problem. But it could just be that it popped out or the plug came off.
lol, on every Z6 I've ever seen that is where its at.. Unless I've been crazy for the last decade plus.
This IAT sensor is like $16 MSRP from the dealer. Any cool parts guy should hook it up for $13-$14. Honda part number 37880-P05-A00
Our next step is to troubleshoot your O2 CEL. Follow the steps in the following flow chart, let me know if you have any questions or if you run into any issues.
thx for all the info. i'll try that. is there possibility my both o2 sensor has to be replaced? cuz i know the o2 sensor on the header is bad (according to the friend mechanic).
If you replace the O2 sensor without doing the troubleshooting in the charts, then you might unnecessarily replace a good sensor and be right back where you are now.
See that is the problem with a lot of peoples attempts to fix a CEL, they don't troubleshoot the system but just start throwing parts at it. Me on the other hand, if I ever get a CEL I'm keeping my fingers crossed that it is a damn short or something. Its so much nicer to fix something with some wire I have laying around, a little solder and heat shrink, and electrical tape to re-loom the harness. Because that repair would cost me nothing but some time. Much better IMO than spending sometimes hundreds on parts just to have the same issue.
And that is also why I have no problem walking people through TRUE troubleshooting. These flow charts is why FACTORY service manuals are the ****, and $20 Chilton or Hayes manuals suck *****.
X2
Yup Yup,
Always Trouble shoot things first, if you throw parts at a car you'll be pissed when you buy a part n it doesn't fix it, then you find out it was a loose connection or sumthin simple...
