starting my car with stock ecu?
hey everyone i just bolted on a turbo kit on my gsr, and i heard that since i changed my injectors to 750cc injectors and installed a 255 walbro fuel pump that the car wont start because i have a stock ecu. i havent tried start the car yet but i just wanted to ask people before i f something up.
Don't do it. Get a ECU with a basemap for your setup, start it and make sure it idles fine and doesn't over heat. Then drive straight to the tuner.
you can drive it on stock ecu and stock injectors as long as you don't go into boost
just remove the charge pipe from the intake
fixed
fixed
true and false
the car will not start with stock ecu and bigger injectors
you can run it on stock injectors and stock ecu, but do no beat on it
you dont need to undo the charge pipes or anything as long as you stay out of boost you will be perfectly fine
do not drive around with the charge pipes undone as it can overspin the turbo
true and false
Hopefully he will chime in
no i need to get a boost gauge. just trying to find out whats the different between a mechanical boost gauge and a electrical boost gauge, and why is the electrical boost gauge 200 bux and the mechanical boost gauge is 60 bux????
since you dotn have any idea of boost...
dont floor the gas at all....not even from a dead stop 1k-2k range. dont even go half way with the pedal.
dont go above 3500 rpms.
as for the gauges.. mechanical is quicker reading, electrical is a tad bit slower in response.
Going wide open throttle will cause the turbo to spool up at a certain RPM, depending on what turbo you have. Its very tempting, but you can do it. ;-)
averyvm
Engine Management and Tuning
Aug 22, 2013 11:02 AM
fastludeh22
Feb 13, 2003 12:24 PM
