'00 Civic - Motor Bogs Then Sudden Renewed Power ?
Long Story short, I bought a 4dr. that some guy had completely trashed. Exterior,Interior and Motor-wise. I'm In The Process of Trying To Revive This Car To At least Be acceptable To Drive Without Draining my Pockets every week ... :/
When I Drive Around, Randomly The Car Will Bog Down Hard, Sometimes Backfiring, Then All Of a Sudden It's Like An Angel Touches The Car And The Car Gains Smooth, Massive Power Back.
My Gas Consumption is crazy, BTW. I can Run Out a Full Tank in 3 Days.
Any Idea's ?
Any Idea's ?
Also, The Cap I Have No Idea, As Far As I'm Concerned with the Dumb guy I bought this car off of, The cap has never been replaced ...
try changin the cap and the rotor button. that would be where i would start. they are cheap, as far as cleaning the injectors its not that they are dirty but they are sticking open, if thats the case.
OMG, Worst day ever for this car now.
Changed the plugs yesterday + Gapped properly. Full Tank of Gas (Why do the worst Things happen to a car AFTER you drop money in the gastank ? haha)
Yesterday checked the coolent and filled accordingly.
TODAY
- Extreme loss of power + sometimes not even wanting to crank + Massive overheating.
Checked the headgasket - All is well.
I'm sooo lost right now. It's like everything I troubleshoot Isn't the case ...
TODAY
- Extreme loss of power + sometimes not even wanting to crank + Massive overheating.Checked the headgasket - All is well.
yea i wasnt thinking about fuel. prime the car by turning on the ignition and then turn it off. GO to the fuel filter and losen the 6mm bolt on top. It has a 10 mm head on it. check and make sure fuel shoots out. if not then there are three or more things that could be wrong.
1: the fuel pump is shot.
2: the filter is clogged.
3: the injectors are leaking.
4: the main relay is going out.
rfdean
18
Dec 5, 2011 10:14 PM
crxjarred
Jun 10, 2011 03:06 PM
Insane Si Lum
Feb 8, 2006 02:14 PM
, ECU is all Stock my Friend.
