Motorola MAP sensor install question
I am about to put on my turbo kit and I decided to install my Motorola MAP sensor before I put all the other stuff on...
Now it just wants to die, do I have to have it tuned to the new MAP sensor? I thought it would run the same but just more maps to compensate for going over 11 psi of boost?
You need to set the scalar and offset and re-tune. You can't just plug it in and call it a day and expect it to run like a stock MAP sensor. I know when I pluged in my Motorola 2.5 bar, I had to re-tune. I know all my buddies who switch MAP sensors had to re-tune.
BUT... if you plan to turn up the boost, past what you were tuned at before, THEN you must tune. Only because you haven't tuned for that level of boost yet.
austrian type-R
Sep 1, 2001 05:16 PM
