knocking sound
Old Jul 5, 2009 | 12:14 AM
larbear90's Avatar
Default knocking sound
I just bought a 98 Civic Hatch not too long ago but it has been at the shop until yesterday because i was applying fat matt. When I took it out last niight for the first time it was making a weird knocking noise.
You can hear it when:
Its idling in neutral
Low RPMs in any gear, if i floor it then it kind of goes away
The noise goes away whenever i depress the clutch whether in neutral or gear.
It has 131000 miles. What could be wrong? Thanks
Old Jul 5, 2009 | 09:54 AM
larbear90's Avatar
Default Re: knocking sound
anyoneee??
Old Jul 5, 2009 | 10:07 AM
tx_ej8_49's Avatar
Knocking or ticking?...Normally, knocking comes from the bottom end(Bearing). Ticking normally comes from the top end(incorrect valve lash). Just hope it is pinging/gas knocking or out of adjusted valves and not a lower-end bearing knock.
Old Jul 5, 2009 | 01:13 PM
iliv2xlr8's Avatar
Do a compression test...
Adjust the valves...
If knocking remains, then start making plans for a swap.
Old Jul 5, 2009 | 02:27 PM
VTAC-KAT's Avatar
is the clutch original? it could be the throw-out bearing
Old Jul 5, 2009 | 03:35 PM
92eg_h22's Avatar
yeah i was gonna go with something in the clutch/tranny if it goes away when u depress the clutch.
Old Jul 5, 2009 | 05:33 PM
larbear90's Avatar
I'm thinking knocking. I don't really know the difference between two. Ya I don't think it's the engine. Cuz the engine wouldn't stop knocking if clutch is depressed. I read somewhere else it's the throwout bearing. How do I check? I have access to a shop. Thanks
Old Jul 5, 2009 | 09:37 PM
larbear90's Avatar
maybe its a little bit more like ticking.
Old Jul 6, 2009 | 10:14 AM
tmoney123's Avatar
check your oil when my civc made a knocking noise it was already too late could mean u r running on low oil or none at al. so u might need oil
Old Jul 6, 2009 | 10:17 AM
ej8ster96's Avatar
to check your throw out bearing, you have to take out the tranny, and you will see it
Old Jul 6, 2009 | 06:59 PM
larbear90's Avatar
clutch and oil in the engine? im not a mechanic but i dont think those have anything to do with each other. There is oil though because i had the valve cover removed last week. im gonna change engine oil and transmission oil.
Anyone know where i could get a good deal on a transmission just in case the transmission is going bad?
thanks!
Tyler Harteau
Jan 4, 2021 08:45 PM
DeeJaaY209
14
Sep 15, 2013 10:40 PM
bbrian
Jun 11, 2013 05:07 PM
ekblack9
23
Mar 14, 2007 10:26 AM
hardcore
Aug 19, 2002 05:29 PM
