Subs cut out sometimes ???
Old Jul 2, 2009 | 01:55 PM
jsteadman's Avatar
Default Subs cut out sometimes ???
I have a 500 bazooka pushing two 12 inch subs...(idk what brand) they used to work fine, then i reinstalled them after a head unit changeand now the amp sometimes cuts off. the light turns red which to my understanding means its getting power, but isnt pushing.......sooooooo idk.....what might be wrong??
Old Jul 3, 2009 | 03:42 AM
john666's Avatar
Default Re: Subs cut out sometimes ???
check your grounds .
Old Jul 4, 2009 | 04:26 PM
jerzzehook's Avatar
New User
If your grounds are good check the remote wire to the head unit it may be loose or have a short
Old Jul 4, 2009 | 06:12 PM
fcm's Avatar
fcm
Old Fart
If amp is turning on and you have no sound then I would check all the speaker wire connections, at the amp and at the speakers, [subs]. 94
Old Jul 5, 2009 | 04:14 PM
01Accordf23's Avatar
If it was the remote wire your amp would cut off completely. Most problems like these are either a bad ground or your amp can't power what you have it may be gettin hot. If you are listening to your music loud and have your gain and everything adjusted real high it's probably your amp not being capable of running that high. Also, if it's a mono channel amp that is 500w peak power and your trying to push two 12's, it's probably over heating. If you knew the exact specs of the speakers and amp I could def diagnose it fir you.
Old Jul 5, 2009 | 04:33 PM
ken9's Avatar
I use to have this problem so yes i would double check the ground, power wire, remote, and check wire on the woofer configuration. Is tha amp new or old? How long was you playing the system? Did the protect light came on while you put the stereo on?
Old Jul 6, 2009 | 03:49 AM
SoCalHatch's Avatar
when the amp goes into protect mode its generally and most likely your ground. the remote wire is obviously good because its getting signal from the head unit to turn on then going into protect mode. so double check the ground or better off find a new one. good luck tho
Old Jul 6, 2009 | 05:21 AM
fcm's Avatar
fcm
Old Fart
If you checked the speaker wiring and it is good you will need to get the make and model of the subs and the model of the amp.
Also need to know the gauge of the power and ground cable, how long the ground cable is and where and how it is grounded?
What kind and size of fuse is in the amps power cable?
Without the above info we are just guessing. 94
Old Jul 8, 2009 | 08:04 AM
jsteadman's Avatar
THANKS!!!! even though i didnt reply to any of your help posts, all of them have helped me in this situation....thank you soo much...i think i got it fixed..i think it was the grounds
98civdx
Audio / Security / Video
Jan 3, 2012 09:12 PM
boostedjdmdc2
Feb 23, 2009 05:08 PM
ef_88_hatch
13
Sep 13, 2008 12:53 PM
notguilty411
15
Apr 5, 2005 01:56 PM
intenseEK
23
Dec 17, 2003 06:54 PM
