HELP rev limiting at 6600??
Old Aug 21, 2002 | 09:29 PM
JDMchris's Avatar
Default HELP rev limiting at 6600??
ok.. i have a euro b18c4.. ( no vtec pressure switch ).. and an american obd1 p72.. i plug it up today and hook up my afc.. and vtec kicks in but wont rev over like 6600 rpm.. i also have an ls distributer.. could this be why? or could it be that the ecu isnt picking up a vtec pressure sensor..(VTM) code.. cause there is no vtec pressure sensor on the euro engine.. it is throwing a code 22.. which is vtec pressure sensor or vtm.. im just wondering why it is doing this.. have any of yall had a similar problem before?? thanks.. chris
Old Aug 22, 2002 | 03:21 AM
sgT's Avatar
sgT
Default Re: HELP rev limiting at 6600?? (JDMchris)
VTM = vtec pressure switch which you do not have but the ecu is looking for.
You need to hook up the vtm wire to the ecu. If your harness does not have this
wire, you must add it.
Old Aug 23, 2002 | 10:52 AM
itr--779's Avatar
New User
Default Re: HELP rev limiting at 6600?? (sgT)
Or your car is running in safe mode.
do you have check engine light?
know how to test for codes?
Old Aug 23, 2002 | 11:21 AM
Dave-ROR's Avatar
Default Re: HELP rev limiting at 6600?? (itr--779)
did you read his post?
Old Aug 23, 2002 | 11:27 AM
sneakychaos's Avatar
Default Re: HELP rev limiting at 6600?? (SoFreshAndSoCleanClean)
What post?
Eli Mac 67
Jun 6, 2007 05:01 PM
nutball72
Aug 26, 2006 10:54 AM
inline4
Jul 27, 2006 03:05 AM
9WON4
Jun 2, 2006 06:11 PM
sharkcohen
Mar 11, 2005 07:55 AM
