1st time at the track, comments please!!!
I finally made it to the track tonight, and this is what my results were. Keep in mind this was my first time ever at the track, so don't flame me too bad
It was pretty busy so I only got 2 runs in
Nice and cool out though.
Car Specs:
1995 Accord EX Sedan 5spd
Greddy Header
AEM CAI
Greddy EVO
Front tire pressure @ 20 psi
All KYB AGX set to stiffest setting
1/8 tank of gas
Stripped of passenger seat, rear seat and spare tire
1st Run:
R/T: .726
60: 2.646
330: 7.164
1/8: 10.863
MPH: 66.63
1000: 14.061
1/4: 16.788
MPH: 82.63
2nd Run:
R/T: .768
60: 2.569
330: 6.971
1/8: 10.627
MPH: 67.93
1000: 13.765
1/4: 16.419
MPH: 85.36
All in all, i'm somewhat satisfied. I had a blast, i know that. I figure if I have a better R/T, I will make low 16's. My second run, I spun out a bit at the start, and I still did better. I also shifted much later than my first run. What gear should I be in at the end of the run? I was in 3rd on my second run. Any tips would be great!!
Nice and cool out though.Car Specs:
Greddy Header
AEM CAI
Greddy EVO
1/8 tank of gas
1st Run:
R/T: .726
60: 2.646
330: 7.164
1/8: 10.863
MPH: 66.63
1000: 14.061
1/4: 16.788
MPH: 82.63
2nd Run:
R/T: .768
60: 2.569
330: 6.971
1/8: 10.627
MPH: 67.93
1000: 13.765
1/4: 16.419
MPH: 85.36
your 60 ft should be 2.3xx and possibly 2.2xx which will bring your times to around 16.0 and with some quicker shifting you really should be able to run a 15 something on that setup...practice practice practice
your reaction time does not affect your e/t...
[Modified by F23 Power, 11:57 PM 8/21/2002]
turbo?
Your 60 foots need work homey.
damn, that is surprising about that civic...h22 only fit with a modified engine bay and a turbo would definitely not fit right, are you sure it wasn't a b16 or b18 motor with a turbo?
and also, your 60 ft's are all about take off...are you getting good traction through first? and also, what rpm do you launch at ?
so try and not jump to conclusions and state false information that other may believe
H22 fits fine in a civic. The 92-95 civics you have the beat the frame rail in a little, but it does fit. The 96-00 civics need no modifications except motor mounts.
I'm guessing that you should be running mid 15's at least. Just work on that 60-foot time. I hit a 16.2 my first time at the track(after having the car for about three days), and my best the second time was a 16.116, but I never practice racing except when I go to the track, so I'm not that good, but I still pulled a 2.316 60-footer. My car is stock though, so I think that you should be able to do better.
About that civic, his license plate said H22T.... plus I looked and I know an H22 when I see one
Mid 15's I could be running? Damn, I did shitty. I thought I was aiming for low 16's since I saw a few 97 and up preludes run 15.7's...I guess they did shitty too. Oh well, i'll practice my launches. I didn't even look at my rpm's that I launched, I'm a n00b
Try a little more air in the tires, I usually stagger mine fl,26 and fr,24. I believe this helps. Try riding the clutch a little more and launch with as little wheel spin as possible. I've managed a 9.9 @ 70 in the 1/8 with similar mods. But I am thinkingI will see high 15s at close to 90
well if grandmarkie was a little better then me i believe it was my first time at the track as well but i only got one run i had to watch my little bro but we did go up agaisnt each other, my car
93 del sol s (stock 105hp)
CAI, 2.25" cat-back, and thats all my tire pressure was also set at 20psi
my times were
r/t ...... .737
60' ...... 2.671
330 ..... 7.347
1/8 ...... 11.214
mph .... 64.16
1000 .... 14.552
1/4 ..... 17.366
mph ..... 80.16
i'm happy with it i guess, bu i think i could have done better, i shifted into 4th at the last second kind of but i think i should have stayed in 3rd, that and i wasnt sure where the 1/4 mile ended.. but theres a noob for ya
my times were
r/t ...... .737
60' ...... 2.671
330 ..... 7.347
1/8 ...... 11.214
mph .... 64.16
1000 .... 14.552
1/4 ..... 17.366
mph ..... 80.16
[QUOTE]Car Specs:
Greddy Header
AEM CAI
Greddy EVO
1/8 tank of gas
QUOTE]
first off nice car, nice setup and oOO nice shocks what springs are you on?
like brian said your 60ft's should be lower that will help your times my car
95 EX Coupe 5spd
AEM CAI - Kamikaze Header - Custom Mandrel Bent 2.5 Catback
Gutted Trunk, 23psi Tires, 1/4-1/2 Tank Gas
thats how i had it at the time and we pushed it too 15.9
if i can find the slips ill give you my 60ft's ect..
oh i do remember lol my R/T's 3 runs in a row..
.666
Greddy Header
AEM CAI
Greddy EVO
1/8 tank of gas
QUOTE]
95 EX Coupe 5spd
.666
95 EX Coupe 5spd
.666
95 EX Coupe 5spd
.666
.666 3 times eh? Sounds very satanic to me
dont forget to "DOUBLE CLUTCH LIKE YOU SHOULD" lol
