My GSR swap IS SLOWER THEN BEFORE?? Car sputters at start after letting sit
Old Jun 30, 2009 | 04:35 PM
JoshJosephKeith's Avatar
Default My GSR swap IS SLOWER THEN BEFORE?? Car sputters at start after letting sit
Okay so Ive noticed my track times this week were alot worse then before..
Before I had an GSR swap.. LS cable trans.. Blox intake manifold.. Comptech use header.. ran a 13.7 with a 2.23' 60 foot with shitty tires on HX wheels.
THEN: Swapped out the LS trans with a gsr HYDRO trans.. got the cable to hydro conversion.. I have 1mm wider then stock throttle body (str throttle body, wont make a difference i know.. looks nice though) I have new tires on the hx's now.. but CANT do better then a 14.4 with a 2.31' 60 foot.. Im losing power I guess??
After I let the car sit over night then go out in the morning to go to work.. start it up it sputters for a few seconds at low rpms.. after it warms up it goes away.. I cant seem to figure out what the problem is? There is NO smoke coming out of the exhaust..
I am running a P06 chipped tuned off CHROME.. vtec at 5300 but hits at 5800?? and 2 step is supposed to be at 4500 but hits at 5000? and my shift light which is the check engine light.. which is at 8200 has stopped coming on?? when I put a stock ecu in vtec hits at the right point on the tach.. but the car runs like **** with both ecu's
maybe I have more then one problem Im not sure.. would appreciate all the help I can get THANK YOU
Old Jun 30, 2009 | 07:19 PM
Default Re: My GSR swap IS SLOWER THEN BEFORE?? Car sputters at start after letting sit
bump
Old Jun 30, 2009 | 07:44 PM
ek-g6's Avatar
Maybe you should either get it retune with a new ecu, or check on your current ecu, your current one might be bad.
Old Jul 1, 2009 | 04:44 AM
yea but i can put the stock ecu in and it still runs like ****.. just even worse.. so im thinkin it sumthing besides the ecu..?
Old Jul 1, 2009 | 05:28 AM
dephtone's Avatar
Are you throwing any codes? If the car is obd1, which it is I assume, jump the wires and tell us what code.
Is the GSR bone stock other than the str throttle body?
Old Jul 1, 2009 | 06:27 AM
It is NOT throwing any codes.. should I jump it to see if it will? I dont think thats how it works though lol.. and it is obd1.. And It has a BLOX intake manifold and comptech USA header.. other then that its pretty stock.
Old Jul 1, 2009 | 02:30 PM
BUMPA DUMPA DUMPA DOOOooo
Old Jul 1, 2009 | 06:04 PM
DCRB's Avatar
do you have a cat. on your car still? check that, make sure it's not pluged. and just because your CEl isn't comming on doesn't mean you're not throwing a code. check to see if you have any codes and post here.
Old Jul 1, 2009 | 06:09 PM
Bunger's Avatar
Are your traps about the same??? Shorter gearing doesn't always equal faster 1/4's.
r1chst3r
Jun 23, 2008 03:14 PM
ateggy1
Mar 17, 2008 09:27 PM
LSVtecHatchback
Aug 31, 2005 07:56 PM
Prod
Sep 24, 2004 08:44 AM
filtereds0ul
Nov 12, 2003 09:30 PM
