***NEED HELP WITH EK FUEL PUMP ASAP***
Old Jun 30, 2009 | 10:40 AM
Aventuraa's Avatar
Default ***NEED HELP WITH EK FUEL PUMP ASAP***
Hey guys what going on. I need urgent help with my fuel pump. Not so long ago i change my wiring harness on my b series motor for some odd reason it stop working. I turned the fuel pump direct from the car battery and i turns on i checked the fuel pump wiring still shooting electrciy check the fuses they all good. Please help
Old Jun 30, 2009 | 10:49 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: ***NEED HELP WITH EK FUEL PUMP ASAP***
huh? slow down. you will not die. rephrase your question. any cel? does the pump prime?
Old Jun 30, 2009 | 10:54 AM
Aventuraa's Avatar
im new to this dont know what you mean by the pump priming please be more specific.
Old Jun 30, 2009 | 11:07 AM
Aventuraa's Avatar
help ne1
Old Jun 30, 2009 | 11:09 AM
I'm not Rick!
not to be a jerk but when you type try to get your words correct. it could mean 2 different things to us.
when you turn the key to on(not turning the motor over) you should a whining noise from under your back seat.
Old Jun 30, 2009 | 11:10 AM
I'm not Rick!
it could just be old, replace it with a walboro
Old Jun 30, 2009 | 11:18 AM
Aventuraa's Avatar
yea i turn the key on and it does not make the whining noise that it should make. And like i said before the pump is still good I checked it.
Old Jun 30, 2009 | 11:22 AM
I'm not Rick!
so its good? then whats your question?
Old Jun 30, 2009 | 11:26 AM
Blk00EJ8's Avatar
not to be a jerk either, but he said the pump primes fine and he changed his harness. why suggest he replaces his pump?
op - chances are you need to do the pin swap that goes to the ECU for the fuel pump. I guess it's not really important which car you have, but rather which pin is in place for your pump.
on an OBD2B harness, the A15 pin on the ECU side is empty while the A16 plug is for the fuel pump relay on a Civic (typically d series). A15 is used for the fuel pump relay on an Integra and A16 is empty. I don't know what your setup is, but if you have the pin in one slot, try switching it to the other one. take a look:
Old Jun 30, 2009 | 11:27 AM
Aventuraa's Avatar
Ok I guess there is som esort of miscommunication here. I took the fuel pump out of my car checked it with my battery, and it turns on. As soon as put it back in my vehicle and i connect it does not want to turn on. I checked the fuses and they are good.
Old Jun 30, 2009 | 11:28 AM
I'm not Rick!
pgmfi relay
Old Jun 30, 2009 | 11:30 AM
I'm not Rick!
[QUOTE=Blk00EJ8;39087078]not to be a jerk either, but he said the pump primes fine and he changed his harness. why suggest he replaces his pump? QUOTE]
becuase i didnt understand the question...duh
Old Jun 30, 2009 | 11:38 AM
Blk00EJ8's Avatar
well then why suggest he starts replacing parts then?
it was pretty clear to me, minus the part about shooting electricity. nonetheless, he's saying that if you wire the pump directly to 12v and ground, it primes. if you have it in the car and try to start the car, it doesn't prime. the op should see my last post. that will likely fix his problem.
Old Jun 30, 2009 | 11:45 AM
I'm not Rick!
at least he got his answer thats what matters
Splock
Jul 30, 2017 08:57 AM
skoolz4loserz
May 10, 2006 06:55 PM
d16y8delsol
Feb 21, 2006 09:26 PM
JRciv
Feb 23, 2005 02:03 PM
Pandahatch93
Feb 1, 2005 11:59 AM
