d16y7 mini me swap
Old Jun 29, 2009 | 12:42 PM
Winkle721's Avatar
Default d16y7 mini me swap
I have a 2000 d16y7, can I use any year y8 head for this swap?
also is changing the ecu to p28 all i need to make the vtec kick?
I know a little about cars but not much about hondas. and do i need to change the wiring harness? or can i run the one i have?
Old Jun 29, 2009 | 12:46 PM
JasonYo's Avatar
Default Re: d16y7 mini me swap
Any year head should be fine, you can even use a z6 head from a older civic but it's a little different.
A p28 is usually recommended but you need a harness to convert from obd1 to obd2B. Make sure it's for a 99-00 not a 96-98.
Old Jun 30, 2009 | 01:21 PM
Winkle721's Avatar
I was told i'm running obd2 and must change to obd1 for this swap.
they said to get it from a 92-95.
Old Jun 30, 2009 | 01:25 PM
HarosGSRek's Avatar
i did this swap i had a 98 though with a d16y7 put a y8 vtec head. as far as vtec idk. i quit the swap and dropped in a gsr motor.
Old Jun 30, 2009 | 01:30 PM
Winkle721's Avatar
anything on the odb1 or odb2?
Old Jun 30, 2009 | 01:33 PM
HarosGSRek's Avatar
obd. sorry no bro.
Old Jun 30, 2009 | 03:42 PM
xtakemoutx's Avatar
pretty sure your gonna need a obd2 harness...
Old Jul 3, 2009 | 07:52 PM
Winkle721's Avatar
does anyone know forsure, when doing a mini-me swap, do you need to run an ecu with odb1 or odb 2?
JAYSCRX420
Nov 30, 2018 06:21 AM
what the ef
Apr 18, 2010 09:09 PM
puertoricanboy90
Feb 1, 2009 09:10 PM
C_R_X_V_T_E_C
Feb 21, 2007 03:54 PM
**DOHC HaTcH**
12
Apr 16, 2006 09:03 AM
