My idle is fluxuating between 900 and 2000
its not like up down up down up down its kinda here and there.
I just had a burnt valve and completly R & R my head and timing belt my knock sensor got broke in the process and I'm not sure why it is doing it.
Also since i did do the timing belt i was wondering how you check the time and make sure its right.
What is the iacv and the other thing you said. Also my cruise control wont engage the light will come on like it is on but it doesnt hold the speed.... Yes there is the one cel for the knock sensor (P0350) I think thats the number anyways the scan tool said knock sensor.
knock sensor is pain if you have to replace it. there not much room to work with unless you take off the intake manifold. I would check if the plug is loose or wires could be frayed. heres a link about the iacv and fitv cleaning.
https://honda-tech.com/forums/honda-accord-1990-2002-2/cleaning-iacv-fitv-tb-1844067/
