eg tb cable with gsr swap ?? help!!
having trouble trying to route the cable on my eg to the gsr intake manifold.. any ideas ? what tb should i use ? should i get an integra tb cable ?
you will most def need to cut the throttle body piece the cable attaches to and extend in longer by atleast 2 inches. i had this same prob with my gsr swap. no cable will work as a direct bolt on unless its a stock cable. stock cable will work!! i prefer the gsr cable tho. with a lil bit of fab work
if u still got the stock gsr tb...go with a stock gsr cable and where the bracket is on the tb that holds the cable ull notice two bolts holding the bracket...just slide the bracket up one bolt so that only one bolt is bolting up the bracket which is the very bottom hole of the bracket, that way the gsr cable will work...thats how i got mine to work on my gsr manifold....
well i have a full gsr swap with gsr tb. and gsr cable did not fit. there was extra cable at the pedal. that is a lie that it will work. you WILL have to extend the tb by inches i promise you that 1. im not saying this for my health. the length of integra tcable is longer than civic one thats how you get extra cable at the pedal. so go ahead and try what seven fc said then ill see you back here saying it didnt work
well ok he might be correct depending on what year the gsr swap is, my gsr has no adjustment to move the tb is why i had to cut and extend my tb 2 inches. btw2 my gsr is a 2000
well im bored at work and desided to measure the plate i welded on my tb to extend it. its a 1inch and 1/4 piece of iron. it doesnt matter what tb u use integra cables are longer than civic ones.
Do your self a favro and buy the type r style intake manifold. Its cheap, then buy any throttle that fits. I got a bdl. Then go to Honda an order a type R throttle cable and bracket. Hexa cheap and looks nice and no more coolant thing on the bottom of the TB. Iacv right to intake mani. Very simple not too much $.
oh damn i didnt know that would take that dumb *** coolant line off. ima have to do that myself now that i know that. i just got a stock gsr intake and tb with gsr cable. looks ugly as **** lol i hate that line ontop of tb
import-tooner
Jan 25, 2011 05:30 AM
