96-98 fog light problem
so i hooked up my yellow square fog lights, and they worked for a few days, and now they wont, i tried plugging them into different spots on the fuse box, worked in one other spot and sure ebought within an hour, they went out, idk what the problem is, fuse is good, bulbs ar fine, everything plugged up well, grounds are located in good spots, but the damn things just wont come on, checked the wires too, all of them are good, idk what the problem is im con-****in-fuzzled( i made that up, lol)meanin fuggin confused, can someone help, please
I presume you have the replica fogs right? If so, are you drawing the power straight from the battery? If not, then wire up the main power to the battery. Secondly check your wiring to your relay. 9/10 times the wiring to the relay is wrong, i've seen 2 cases and both times it was wired wrong.
it is wired to the battery, and yes they are replicas, i will check the wiring on the relay, is there any way you can show me a pic on how it is supposed to look, im not good with wiring
so, im stuck on these lights, i went out and got a new relay, and i grabbed a flasher relay, so my fogs just sat there and flashed, replaced it with a different one, and now they still dont work, how do i re wire the relay that came with the fogs? anyone know?
raidacaipo
Mar 11, 2009 11:40 AM
stupidwhitecat
Mar 25, 2005 06:21 PM
