Fog light electrical help
Hey guys. I just got some OEM fog lights for my 94 civic. I wired everything and tested the lights out and everything worked fine. Then after I got everyting hooked up and finished I went to test them out a final time and they keep blowing the fuse. When I tested them out at first I turned them on and off about 3 times no problem. But then after I finalized everything and finished up, the fuse keeps blowing. I can't think of anything that I changed. I had 3 spare 15 fuses and each one blew the first time when trying to turn them on. The power is from the battery. I don't know what's going on.
Re: Fog light electrical help (stupidwhitecat)
Make sure you hooked up the wires correctly on the relay. That was the cause of the exact same problem you're describing for a few of our customers.
thisboyjulio
11-10-2008 03:50 PM
